跳转到主内容
Ridgid GEN5X R8642 Gear Assembly Replacement
你所需要的
  1. Ridgid GEN5X R8642 Gear Assembly Replacement, Gear Assembly: 步骤 1 中的图像 1,1
    • Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
  2. Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the handle cover by pulling it towards the front of the saw.
    • The grip can sometimes become stuck and may require a decent amount of force to remove.
  3. Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 3 中的图像 1,2 Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 3 中的图像 2,2
    • Use a T20 Torx screwdriver to remove the nine M4 X 16mm screws from the plastic housing.
  4. Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 4 中的图像 1,1
    • Use a JIS #1 screwdriver to remove the two M4 x 25mm screws on both sides of the metal housing.
  5. Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 5 中的图像 1,1
    • Remove one half of the plastic housing using a spudger so that the internal system is exposed.
  6. Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 6 中的图像 1,2 Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 6 中的图像 2,2
    • Remove the one 16mm T20 screw that holds the grip support onto the saw.
  7. Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 7 中的图像 1,3 Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 7 中的图像 2,3 Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 7 中的图像 3,3
    • Remove the five T20 Torx screws from the gear assembly cover and pull the cover off.
  8. Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 8 中的图像 1,2 Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 8 中的图像 2,2
    • Carefully remove the motor making sure not to harm any of the wires that are attached. Place motor gently out of the way.
  9. Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 9 中的图像 1,3 Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 9 中的图像 2,3 Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 9 中的图像 3,3
    • Remove the orbital switch by pulling straight up on it.
    • Be careful to not lose the spring and pin that is inside of the switch.
  10. Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 10 中的图像 1,3 Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 10 中的图像 2,3 Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 10 中的图像 3,3
    • Remove the gear assembly by pulling it straight up.
  11. Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 11 中的图像 1,3 Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 11 中的图像 2,3 Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 11 中的图像 3,3
    • Pull the pin holding the metal guide housing in place.
    • Slide the metal guide housing back off the gear assembly.
  12. Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 12 中的图像 1,2 Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 12 中的图像 2,2
    • Remove the guide bushing by pulling up on it.
    • Then slide the pin out that holds the gear assembly and blade clamp assembly.
  13. Ridgid GEN5X R8642 Gear Assembly Replacement: 步骤 13 中的图像 1,1
    • Slide the blade clamp assembly off the gear assembly.
结论
3等其他人完成本指南。
一条评论
When reassembling with new gear, does gear needs to be greased?
Syoma Zv - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 19
总计 1,963
