跳转到主内容
Ridgid GEN5X R8611506 Outer Case Replacement
你所需要的
  1. Ridgid GEN5X R8611506 Outer Case Replacement, Outer Case: 步骤 1 中的图像 1,2 Ridgid GEN5X R8611506 Outer Case Replacement, Outer Case: 步骤 1 中的图像 2,2
    • Orient the drill to have the side with the screws facing up.
    • Using the Torx T10 screwdriver, remove the eight 4.0mm screws from the face of the drill.
  2. Ridgid GEN5X R8611506 Outer Case Replacement: 步骤 2 中的图像 1,3 Ridgid GEN5X R8611506 Outer Case Replacement: 步骤 2 中的图像 2,3 Ridgid GEN5X R8611506 Outer Case Replacement: 步骤 2 中的图像 3,3
    • Orient the drill to where the back is facing up.
    • Using a Torx T10 screwdriver, remove the four 6.0mm screws that attach the back piece to the drill.
    • Remove the back piece of the drill using the iFixit opening tool.
  3. Ridgid GEN5X R8611506 Outer Case Replacement: 步骤 3 中的图像 1,2 Ridgid GEN5X R8611506 Outer Case Replacement: 步骤 3 中的图像 2,2
    • Orient the drill to where the chuck is facing up.
    • Using the Torx T15 screwdriver, remove the four 8.0mm screws from the front of the drill.
  4. Ridgid GEN5X R8611506 Outer Case Replacement: 步骤 4 中的图像 1,2 Ridgid GEN5X R8611506 Outer Case Replacement: 步骤 4 中的图像 2,2
    • Orient the drill so the side with the screw holes is facing up.
    • Use a plastic opening tool to gently pry the face off of the drill.
    • Remove the face completely from the drill.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 250
