跳转到主内容
Ridgid GEN5X R8611506 Gears Replacement
你所需要的
  1. Ridgid GEN5X R8611506 Gears Replacement, Outer Case: 步骤 1 中的图像 1,2 Ridgid GEN5X R8611506 Gears Replacement, Outer Case: 步骤 1 中的图像 2,2
    • Orient the drill to have the side with the screws facing up.
    • Using the Torx T10 screwdriver, remove the eight 4.0mm screws from the face of the drill.
  2. Ridgid GEN5X R8611506 Gears Replacement: 步骤 2 中的图像 1,3 Ridgid GEN5X R8611506 Gears Replacement: 步骤 2 中的图像 2,3 Ridgid GEN5X R8611506 Gears Replacement: 步骤 2 中的图像 3,3
    • Orient the drill to where the back is facing up.
    • Using a Torx T10 screwdriver, remove the four 6.0mm screws that attach the back piece to the drill.
    • Remove the back piece of the drill using the iFixit opening tool.
  3. Ridgid GEN5X R8611506 Gears Replacement: 步骤 3 中的图像 1,2 Ridgid GEN5X R8611506 Gears Replacement: 步骤 3 中的图像 2,2
    • Orient the drill to where the chuck is facing up.
    • Using the Torx T15 screwdriver, remove the four 8.0mm screws from the front of the drill.
  4. Ridgid GEN5X R8611506 Gears Replacement: 步骤 4 中的图像 1,2 Ridgid GEN5X R8611506 Gears Replacement: 步骤 4 中的图像 2,2
    • Orient the drill so the side with the screw holes is facing up.
    • Use a plastic opening tool to gently pry the face off of the drill.
    • Remove the face completely from the drill.
  5. Ridgid GEN5X R8611506 Gears Replacement, Speed Selector Switch: 步骤 5 中的图像 1,1
    • Locate the selector switch.
    • Unhook the selector switch from the small silver wire located near the top of the drill.
  6. Ridgid GEN5X R8611506 Gears Replacement: 步骤 6 中的图像 1,1
    • Remove the speed selector switch from the case housing.
  7. Ridgid GEN5X R8611506 Gears Replacement, Gears: 步骤 7 中的图像 1,1
    • Pull the motor and chuck out of the drill casing.
  8. Ridgid GEN5X R8611506 Gears Replacement: 步骤 8 中的图像 1,2 Ridgid GEN5X R8611506 Gears Replacement: 步骤 8 中的图像 2,2
    • Orient the motor and chuck to where the back of the motor is facing up.
    • Using a Phillips #0 screwdriver, remove the four 5.0mm screws that connect the motor to the chuck.
  9. Ridgid GEN5X R8611506 Gears Replacement: 步骤 9 中的图像 1,2 Ridgid GEN5X R8611506 Gears Replacement: 步骤 9 中的图像 2,2
    • Pull apart the motor from the chuck to expose the gears.
    • Remove the four gears located within the motor/chuck housing.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 8
过去 30 天: 34
总计 728
