跳转到主内容
Ridgid Circular Saw R3205 Spindle Lock Replacement
你所需要的
  1. Ridgid Circular Saw R3205 Spindle Lock Replacement, Blade: 步骤 1 中的图像 1,2 Ridgid Circular Saw R3205 Spindle Lock Replacement, Blade: 步骤 1 中的图像 2,2
    • Press the black spindle lock and hold it down.
    • While keeping the spindle lock pressed down use a 6mm allen wrench to remove the 5/16-18 x 0.55 inch screw.
  2. Ridgid Circular Saw R3205 Spindle Lock Replacement: 步骤 2 中的图像 1,1
    • Release the spindle lock and remove the outer flange by lifting it off the output shaft.
  3. Ridgid Circular Saw R3205 Spindle Lock Replacement: 步骤 3 中的图像 1,3 Ridgid Circular Saw R3205 Spindle Lock Replacement: 步骤 3 中的图像 2,3 Ridgid Circular Saw R3205 Spindle Lock Replacement: 步骤 3 中的图像 3,3
    • With the outer flange removed retract the lower blade guard into the upper blade guard housing by pushing on the black lever.
    • Slide the blade out of from the bottom of the saw.
  4. Ridgid Circular Saw R3205 Spindle Lock Replacement, Lower Blade Guard: 步骤 4 中的图像 1,2 Ridgid Circular Saw R3205 Spindle Lock Replacement, Lower Blade Guard: 步骤 4 中的图像 2,2
    • Use a prying tool or your fingers to remove the inner flange.
  5. Ridgid Circular Saw R3205 Spindle Lock Replacement: 步骤 5 中的图像 1,3 Ridgid Circular Saw R3205 Spindle Lock Replacement: 步骤 5 中的图像 2,3 Ridgid Circular Saw R3205 Spindle Lock Replacement: 步骤 5 中的图像 3,3
    • Remove the external retaining ring with a screwdriver by expanding it and then prying it out.
  6. Ridgid Circular Saw R3205 Spindle Lock Replacement: 步骤 6 中的图像 1,1
    • After removing the external retaining ring, remove (OD50 x ID42 x 0.8t) washer.
  7. Ridgid Circular Saw R3205 Spindle Lock Replacement: 步骤 7 中的图像 1,2 Ridgid Circular Saw R3205 Spindle Lock Replacement: 步骤 7 中的图像 2,2
    • Remove the lower blade guard after removing the washer.
  8. Ridgid Circular Saw R3205 Spindle Lock Replacement, Spindle Lock: 步骤 8 中的图像 1,1
    • Remove the (M3 x 12 mm) screw using a phillips head screwdriver.
  9. Ridgid Circular Saw R3205 Spindle Lock Replacement: 步骤 9 中的图像 1,1
    • Leave the rubber dust cover below the removed screw.
  10. Ridgid Circular Saw R3205 Spindle Lock Replacement: 步骤 10 中的图像 1,3 Ridgid Circular Saw R3205 Spindle Lock Replacement: 步骤 10 中的图像 2,3 Ridgid Circular Saw R3205 Spindle Lock Replacement: 步骤 10 中的图像 3,3
    • Pull out the Spindle Lock.
结论
Joshua Caron
于04/05/19注册
792 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 1,477
