跳转到主内容
Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement
你所需要的
  1. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: 步骤 1 中的图像 1,3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: 步骤 1 中的图像 2,3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: 步骤 1 中的图像 3,3
    • Remove the brush assembly with a flat head screwdriver.
  2. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: 步骤 2 中的图像 1,3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: 步骤 2 中的图像 2,3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: 步骤 2 中的图像 3,3
    • Use a T25 Torx screwdriver to remove 3 (M5 x 58 mm) screws.
  3. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: 步骤 3 中的图像 1,3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: 步骤 3 中的图像 2,3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: 步骤 3 中的图像 3,3
    • Use a T20 Torx screwdriver to remove the (1/4-20 x 0.66 in.) screw.
    • After removing the (1/4-20 x 0.66 in.) screw the lever assembly can be unscrewed from the (1/4-20 x 0.66 in.) screw.
  4. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: 步骤 4 中的图像 1,2 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: 步骤 4 中的图像 2,2
    • The motor housing assembly can now be removed from the rest of the saw.
结论
Joshua Caron
于04/05/19注册
792 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 10
总计 364
