跳转到主内容
Ridgid Circular Saw R3205 Lower Blade Guard Replacement
你所需要的
  1. Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Blade: 步骤 1 中的图像 1,2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Blade: 步骤 1 中的图像 2,2
    • Press the black spindle lock and hold it down.
    • While keeping the spindle lock pressed down use a 6mm allen wrench to remove the 5/16-18 x 0.55 inch screw.
  2. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 步骤 2 中的图像 1,1
    • Release the spindle lock and remove the outer flange by lifting it off the output shaft.
  3. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 步骤 3 中的图像 1,3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 步骤 3 中的图像 2,3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 步骤 3 中的图像 3,3
    • With the outer flange removed retract the lower blade guard into the upper blade guard housing by pushing on the black lever.
    • Slide the blade out of from the bottom of the saw.
  4. Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Lower Blade Guard: 步骤 4 中的图像 1,2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Lower Blade Guard: 步骤 4 中的图像 2,2
    • Use a prying tool or your fingers to remove the inner flange.
  5. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 步骤 5 中的图像 1,3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 步骤 5 中的图像 2,3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 步骤 5 中的图像 3,3
    • Remove the external retaining ring with a screwdriver by expanding it and then prying it out.
  6. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 步骤 6 中的图像 1,1
    • After removing the external retaining ring, remove (OD50 x ID42 x 0.8t) washer.
  7. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 步骤 7 中的图像 1,2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: 步骤 7 中的图像 2,2
    • Remove the lower blade guard after removing the washer.
结论
3等其他人完成本指南。
Joshua Caron
于04/05/19注册
792 声望
创作了5篇指南
团队
一条评论
Thank you so VERY much! I was stuck and this was perfectly described!
Chris Bishop - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 2,043
