简介
This guide is a step-by-step process showing how to get to and remove the wiring harness within the handle of this grinder. This may be helpful in determining an issue with powering the device or replacing faulty wiring. As you work though this guide you will notice number following capitalized parts. These are the key numbers from the visual diagram provided within the Technical Description/Device Page under Additional Information, labeled 'Parts Page and Wiring Diagram.' Steps 1 through 3 are not necessary for this task although they make it easier to work with the tool.
你所需要的
Take hold of the Side Assembly Handle [8] and unscrew to detach from the grinder.
2等其他人完成本指南。
一条评论
Be careful while jointing the wires because it can cause you some electric issues for more info you can read this guide.
