简介
The Riddell SpeedFlex's chinstrap plays a crucial role in ensuring its users' safety out on the football field. If you're experiencing any complications with Riddell Speedflex's chinstrap, such as it feeling loose, constant slipping, or substantial damage causing other issues, replacing the chinstrap can be the solution to your device's malfunctioning.
This guide will provide you with a thorough explanation of the replacement process, with helpful photos along the way to make sure you are successful.
Before you begin, make sure to check the troubleshooting page to guarantee that the facemask needs replacement.
你所需要的
Place your helmet on a reliable, flat, sturdy surface to ensure an easy removal and replacement process.
Position the helmet so that the side closest to you is off the table.
To ensure the quality of the replacement, try the helmet on and run your facemask through some testing.
