简介
The Riddell SpeedFlex's cam-loc system plays a crucial role in ensuring its users' safety out on the football field. If you're experiencing any complications with Riddell Speedflex's cam-loc system, such as it failing to contain the chinstrap, constant unbuckling, or substantial damage causing other issues, replacing the cam-loc system can be the solution to your device's malfunctioning.
This guide will provide you with a thorough explanation of the replacement process, with helpful photos along the way to make sure you are successful.
Before you begin, make sure to check the troubleshooting page to guarantee that the facemask needs replacement.
你所需要的
Place your helmet on a reliable, flat, sturdy surface to ensure an easy removal and replacement process.
Position the helmet so you can see the bowl part of the helmet.
To ensure the quality of the replacement, try the helmet on and run your facemask through some testing.
