跳转到主内容
配件
没有特定配件。
  1. 这个步骤还没有翻译 帮忙翻译一下
    Unscrew the seven indicated screws from the left, right, bottom, and back sides of the camera. Unscrew the seven indicated screws from the left, right, bottom, and back sides of the camera.
    • Unscrew the seven indicated screws from the left, right, bottom, and back sides of the camera.
  2. 这个步骤还没有翻译 帮忙翻译一下
    Loosen the back cover from both the left and the right sides of the camera. Remove back cover. The lid of the battery compartment may fall off because it is not attached to anything. Remove back cover. The lid of the battery compartment may fall off because it is not attached to anything.
    • Loosen the back cover from both the left and the right sides of the camera.
    • Remove back cover. The lid of the battery compartment may fall off because it is not attached to anything.
  3. 这个步骤还没有翻译 帮忙翻译一下
    Open the film compartment. Press your finger on top of the grey latch on the left side of the camera. Press your finger on top of the grey latch on the left side of the camera.
    • Open the film compartment.
    • Press your finger on top of the grey latch on the left side of the camera.
  4. 这个步骤还没有翻译 帮忙翻译一下
    Removing the film compartment door is optional. However, it may aid maneuverability in future steps. Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place. Use your fingers to completely remove the metal pin.
    • Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
    • Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
    • Use your fingers to completely remove the metal pin.
    • Remove the film compartment door.
  5. 这个步骤还没有翻译 帮忙翻译一下
    Using a thin shaft screwdriver, unscrew the two indicated screws within the film compartment. Using a thin shaft screwdriver, unscrew the two indicated screws within the film compartment.
    • Using a thin shaft screwdriver, unscrew the two indicated screws within the film compartment.
  6. 这个步骤还没有翻译 帮忙翻译一下
    Loosen the front cover from the left and right sides of the camera. Remove the front cover. Remove the front cover.
    • Loosen the front cover from the left and right sides of the camera.
    • Remove the front cover.
  7. 这个步骤还没有翻译 帮忙翻译一下
    The lens is only attached to the main camera body. Set the front and back covers aside. Unscrew three screws from the outermost plastic plate covering the lens. After the screws are removed, the outermost plate can be removed.
    • The lens is only attached to the main camera body. Set the front and back covers aside.
    • Unscrew three screws from the outermost plastic plate covering the lens.
    • After the screws are removed, the outermost plate can be removed.
  8. 这个步骤还没有翻译 帮忙翻译一下
    Remove the ring shaped metal brace. Using fingers or tweezers, remove the lens from the camera. Using fingers or tweezers, remove the lens from the camera.
    • Remove the ring shaped metal brace.
    • Using fingers or tweezers, remove the lens from the camera.
终点
Eric Dazet
于2012年04月10日注册
352 信誉积分
创作了5篇指南
团队
Cal Poly, Team 6-21, Amido Spring 2012 Cal Poly, Team 6-21, Amido Spring 2012 的会员
CPSU-AMIDO-S12S6G21
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 474
