简介
This process involves removing the back cover, the front cover, and the zoom mechanism of the camera. After, the lens cover can be removed from the front cover.
工具
配件
无需配件。
Unscrew a total of seven screws from the left, right, bottom, and back sides of the camera.
The following step to remove the film compartment door is optional. However, it may aid in the maneuvering of the camera in future steps.
To remove the film compartment door, take a thin object such as a toothpick or a small screwdriver and push down on the metal pin holding the film compartment door in place.
After pushing the metal pin down, use your fingers to completely remove the metal pin.
After the metal pin has been removed, the film compartment door can be removed.
The lens cover is only attached to the front cover of the camera. Set the rest of the camera aside.
In order to reach the lens cover, the zoom mechanism must be removed.
Unscrew three screws from the front cover that hold the zoom mechanism in place.
Remove the zoom mechanism.
