跳转到主内容
Ricoh Theta S Outer Case Replacement
你所需要的
  1. Ricoh Theta S Outer Case Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Ricoh Theta S Outer Case Replacement: 步骤 2 中的图像 1,2 Ricoh Theta S Outer Case Replacement: 步骤 2 中的图像 2,2
    • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
  3. Ricoh Theta S Outer Case Replacement: 步骤 3 中的图像 1,3 Ricoh Theta S Outer Case Replacement: 步骤 3 中的图像 2,3 Ricoh Theta S Outer Case Replacement: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
结论
Bradley Sutton
于11/07/17注册
737 声望
创作了4篇指南
团队
IUPUI, Team S3-G1, Harley Fall 2017 IUPUI, Team S3-G1, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S3G1
3 名成员
创作了4篇指南
一条评论
Where can find spare part case?
Thanks
Franco - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 21
总计 2,179
