简介
This guide will show the steps required to replace the internal microSD memory card inside the Ricoh Theta S. Be aware that any replacement of disassembly of the original product may void the manufacturer warranty.
  1. Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Use a Phillips #00 screwdriver to remove the four 3-mm screws located on the bottom of the device.
    • Use a Phillips #00 screwdriver to remove the four 3-mm screws located on the bottom of the device.
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
    • The battery is located near the bottom of the device.
    • Flip the plastic containing thermal compound over so it is resting on top of the battery.
    • Lift the battery out of the device, beginning with the end closest to the camera.
    • Remove the two 2mm Phillips screws.
    • Remove the black 2mm Phillips screw.
    • Remove the 1.5mm Phillips screw.
    • Carefully pull the side casing away from the camera.
    • Lift up the plastic containing thermal compound to reveal the thermal tape covering the motherboard.
    • Peel back the lower left corner of the thermal tape to reveal the microSD slot located on the motherboard.
    • Push the microSD card inward, from the side.
    • Once a click is heard, pull the screwdriver away to eject the microSD card from the slot.
结论
Bradley Sutton
于2017年11月07日注册
428 信誉积分
创作了4篇指南
团队
IUPUI, Team S3-G1, Harley Fall 2017 IUPUI, Team S3-G1, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S3G1
3 名成员
创作了4篇指南
I was able to complete this however there is a clear plastic guard running around the bottom half of the Theta S, and the only way to get the SD Card above that guard was to remove a few additional screws. Fortunately was not that complex and reassembly was still successful. Good luck!
jason - 回复
Maximum size of SD Card? 128GB?
just - 回复
浏览统计数据:
过去的24小时: 0
过去的7天: 11
过去的30天: 49
总计 484
