跳转到主内容
Ricoh Theta S Camera Assembly Replacement
你所需要的
  1. Ricoh Theta S Camera Assembly Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Ricoh Theta S Camera Assembly Replacement: 步骤 2 中的图像 1,2 Ricoh Theta S Camera Assembly Replacement: 步骤 2 中的图像 2,2
    • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
  3. Ricoh Theta S Camera Assembly Replacement: 步骤 3 中的图像 1,3 Ricoh Theta S Camera Assembly Replacement: 步骤 3 中的图像 2,3 Ricoh Theta S Camera Assembly Replacement: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
  4. Ricoh Theta S Camera Assembly Replacement, Camera Assembly: 步骤 4 中的图像 1,1
    • Remove the two 3mm Phillips screws, with the Phillips 00 Screwdriver.
  5. Ricoh Theta S Camera Assembly Replacement: 步骤 5 中的图像 1,2 Ricoh Theta S Camera Assembly Replacement: 步骤 5 中的图像 2,2
    • Gently lift the camera assembly from the device until the ribbon cable connections are accessible.
    • Peel back the piece of tape securing the microphone wire the the circuit board.
  6. Ricoh Theta S Camera Assembly Replacement: 步骤 6 中的图像 1,2 Ricoh Theta S Camera Assembly Replacement: 步骤 6 中的图像 2,2
    • Find the two ribbon cable connectors located on each side of the device.
    • Using a plastic spudger, gently lift the black plastic piece of the connector.
    • The images show a screwdriver being used to flip up the tabs of the ZIF connectors, which carries the possibility of shorting the motherboard. Be sure to use an ESD safe tool instead!
  7. Ricoh Theta S Camera Assembly Replacement: 步骤 7 中的图像 1,2 Ricoh Theta S Camera Assembly Replacement: 步骤 7 中的图像 2,2
    • Carefully detach the two ribbons cables from their connectors to remove the camera assembly.
结论
5等其他人完成本指南。
Bradley Sutton
于11/07/17注册
737 声望
创作了4篇指南
团队
IUPUI, Team S3-G1, Harley Fall 2017 IUPUI, Team S3-G1, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S3G1
3 名成员
创作了4篇指南
12条评论
Hello, is there a way to replace the glass the cover the lens? I Have 2 Ricoh Theta, one the glass is broken and other has a scratch that shows in every image… so I want to replace the scratched glass with the good one of the other camera
Willian Machado - 回复
Hello, Where can I find the set of lenses or just the replacement glass?
I am happy if you have a return.
olima - 回复
Having same Issue as Willian Machado, please respond to our questions :) Is there a way to replace a scratched/ broken covering glass if we have two Theta`s ? We can make one full working one by using the two undamaged sides - theorethically. Does it work ?
McTwist - 回复
I also have same issue… Broke part of my glass, will like to find out if its possible to replace just one part of it….
Continent Kofi - 回复
I have one with a shattered lens and took it appart to check…. glass seems to be permanently fixed to optical block with very strong epoxi resin and doesn’t seem to be replaceable even if you manage to clean up, the problem is how to remove a good lens for transplant, without breaking it.
Bravo...!!! - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 36
总计 7,467
