跳转到主内容
Ricoh Theta S Battery Replacement
你所需要的
  1. Ricoh Theta S Battery Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Ricoh Theta S Battery Replacement: 步骤 2 中的图像 1,2 Ricoh Theta S Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
  3. Ricoh Theta S Battery Replacement: 步骤 3 中的图像 1,3 Ricoh Theta S Battery Replacement: 步骤 3 中的图像 2,3 Ricoh Theta S Battery Replacement: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
  4. Ricoh Theta S Battery Replacement, Battery: 步骤 4 中的图像 1,2 Ricoh Theta S Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • The battery is located near the bottom of the device.
    • Flip the plastic containing thermal compound over so it is resting on top of the battery.
  5. Ricoh Theta S Battery Replacement: 步骤 5 中的图像 1,2 Ricoh Theta S Battery Replacement: 步骤 5 中的图像 2,2
    • Lift the battery out of the device, beginning with the end closest to the camera.
结论
7等其他人完成本指南。
Bradley Sutton
于11/07/17注册
737 声望
创作了4篇指南
团队
IUPUI, Team S3-G1, Harley Fall 2017 IUPUI, Team S3-G1, Harley Fall 2017 的会员
IUPUI-HARLEY-F17S3G1
3 名成员
创作了4篇指南
8条评论
Nice demonstration, but if I can’t find a DB-110 replacement battery, I’m not sure if I would take the camera apart. If I find a replacement, this step-by-step demonstration will be very helpful.
Joel Brondos - 回复
The battery replacement for Ricoh Theta S is the Olympus battery model LI-92B.
It’s the perfect equivalent of the original Ricoh DB-110 battery. Tested personally.
Please don’t use any other similar battery or you risk to breaking the charge control circuit of the camera!!
Please note that you nullify the warranty, if the item is under coverage.
Franco - 回复
Do you have a good link for Olympus battery model LI-92B ?
Patrick D - 回复
It its very important to observe to remove the right side of the camera cover ! it is the side without button !!!
wkaemena - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 23
过去 30 天: 87
总计 10,017
