跳转到主内容
Ricoh Shotmaster 130Z Shutter LED Replacement
你所需要的
  1. Ricoh Shotmaster 130Z Shutter LED  Replacement, Shutter LED: 步骤 1 中的图像 1,3 Ricoh Shotmaster 130Z Shutter LED  Replacement, Shutter LED: 步骤 1 中的图像 2,3 Ricoh Shotmaster 130Z Shutter LED  Replacement, Shutter LED: 步骤 1 中的图像 3,3
    • Using a Phillips J00 head remove the three 5mm screws on both left and right side of the camera as well as the one in back of it.
  2. Ricoh Shotmaster 130Z Shutter LED  Replacement: 步骤 2 中的图像 1,1
    • Using the same J00 phillips head screwdriver proceed to removing the remaining four 5mm screws on the bottom of the camera.
    • Last, using the same #00 phillips head screwdriver remove the two 0.6mm screws which are one on each side of the tripod connection dip.
  3. Ricoh Shotmaster 130Z Shutter LED  Replacement: 步骤 3 中的图像 1,2 Ricoh Shotmaster 130Z Shutter LED  Replacement: 步骤 3 中的图像 2,2
    • The case can now be removed from the camera.
    • Using a blue opening tool start by lifting the back part of the case right where the tripod dip is. Lift until the back part of the case is released and can be easily removed
    • Next, using the same opening tool lift and push by the battery compartment as shown in the second picture. Do this until the front part of the case is released and can be easily removed.
  4. Ricoh Shotmaster 130Z Shutter LED  Replacement: 步骤 4 中的图像 1,2 Ricoh Shotmaster 130Z Shutter LED  Replacement: 步骤 4 中的图像 2,2
    • The LED diode to be replaced can be found in the front of the camera next to the zooming lens.
    • Desolder the LED to remove it from the motherboard
结论
团队
UMass Dartmouth, Team 3-4, Isaacson Fall 2016 UMass Dartmouth, Team 3-4, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G4
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 211
