跳转到主内容
Rexing V1P Plus Front Camera Replacement
你所需要的
  1. Rexing V1P Plus Front Camera Replacement, Front Camera: 步骤 1 中的图像 1,3 Rexing V1P Plus Front Camera Replacement, Front Camera: 步骤 1 中的图像 2,3 Rexing V1P Plus Front Camera Replacement, Front Camera: 步骤 1 中的图像 3,3
    • Begin by orienting the device with the LCD screen facing down.
    • Remove the four 6 mm screws, located on the backside of the device, using the Phillips #00 screwdriver.
  2. Rexing V1P Plus Front Camera Replacement: 步骤 2 中的图像 1,3 Rexing V1P Plus Front Camera Replacement: 步骤 2 中的图像 2,3 Rexing V1P Plus Front Camera Replacement: 步骤 2 中的图像 3,3
    • Remove the back cover of the device and place it to the side.
    • Rotate the device 180 degrees to where the camera is facing you.
  3. Rexing V1P Plus Front Camera Replacement: 步骤 3 中的图像 1,3 Rexing V1P Plus Front Camera Replacement: 步骤 3 中的图像 2,3 Rexing V1P Plus Front Camera Replacement: 步骤 3 中的图像 3,3
    • Remove the two 5 mm screws next to the lens using the Phillips #00 screwdriver.
  4. Rexing V1P Plus Front Camera Replacement: 步骤 4 中的图像 1,3 Rexing V1P Plus Front Camera Replacement: 步骤 4 中的图像 2,3 Rexing V1P Plus Front Camera Replacement: 步骤 4 中的图像 3,3
    • Remove the two camera angle adjusters from the side of the device and carefully pull out the lens.
  5. Rexing V1P Plus Front Camera Replacement: 步骤 5 中的图像 1,3 Rexing V1P Plus Front Camera Replacement: 步骤 5 中的图像 2,3 Rexing V1P Plus Front Camera Replacement: 步骤 5 中的图像 3,3
    • Remove the two 5mm screws securing the camera support bracket using the Phillips #00 screwdriver.
  6. Rexing V1P Plus Front Camera Replacement: 步骤 6 中的图像 1,3 Rexing V1P Plus Front Camera Replacement: 步骤 6 中的图像 2,3 Rexing V1P Plus Front Camera Replacement: 步骤 6 中的图像 3,3
    • Carefully remove the plastic frame piece from its previously secured position on the motherboard.
    • It will rest loosely around the white camera ribbon.
    • Rotate the device 180 degrees to where the camera is facing away from you.
  7. Rexing V1P Plus Front Camera Replacement: 步骤 7 中的图像 1,3 Rexing V1P Plus Front Camera Replacement: 步骤 7 中的图像 2,3 Rexing V1P Plus Front Camera Replacement: 步骤 7 中的图像 3,3
    • Carefully peel back the adhesive material covering the ribbon cable connection.
  8. Rexing V1P Plus Front Camera Replacement: 步骤 8 中的图像 1,3 Rexing V1P Plus Front Camera Replacement: 步骤 8 中的图像 2,3 Rexing V1P Plus Front Camera Replacement: 步骤 8 中的图像 3,3
    • Using the Flathead 1.5mm screwdriver, or another pry tool, gently flip up the black ZIF connector locking flap to free the ribbon cable.
    • Once the connector is open, slide the ribbon cable out to remove it.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 224
