跳转到主内容
Revlon RVIR1008 Disassembly
你所需要的
  1. Revlon RVIR1008 Disassembly, Revlon RVIR1008 Disassembly: 步骤 1 中的图像 1,1
    • Be sure your curling iron is removed from the electrical outlet. Failure to unplug may result in electric shock and/or damage to the curling iron.
    • Place the curling iron on a clean, flat surface.
  2. Revlon RVIR1008 Disassembly, Remove the metal stand.: 步骤 2 中的图像 1,1
    • Use your fingers to pull the ends of the stand away from the barrel. The metal stand should be easy to pry from the sides of the barrel.
  3. Revlon RVIR1008 Disassembly, Remove the barrel clip.: 步骤 3 中的图像 1,2 Revlon RVIR1008 Disassembly, Remove the barrel clip.: 步骤 3 中的图像 2,2
    • Using a 3mm Flathead screwdriver, slowly remove both screws from the sides of the barrel clip.
    • Take turns unscrewing each screw . The clip is operated by a tight metal spring. Completely removing one screw first makes it difficult to unscrew the second screw.
  4. Revlon RVIR1008 Disassembly, Remove the clip spring.: 步骤 4 中的图像 1,2 Revlon RVIR1008 Disassembly, Remove the clip spring.: 步骤 4 中的图像 2,2
    • Using two fingers, squeeze either side of the spring and slide the ends away from the barrel.
  5. Revlon RVIR1008 Disassembly, Remove the spring plate: 步骤 5 中的图像 1,1
    • Using a 3mm Flathead Screwdriver, remove the screw holding the spring plate in place.
  6. Revlon RVIR1008 Disassembly, Remove the bottom of the handle.: 步骤 6 中的图像 1,3 Revlon RVIR1008 Disassembly, Remove the bottom of the handle.: 步骤 6 中的图像 2,3 Revlon RVIR1008 Disassembly, Remove the bottom of the handle.: 步骤 6 中的图像 3,3
    • Using a 3mm Flathead Screwdriver, remove the 27mm screw on the left and the 15mm screw on the right.
    • When reassembling the curling iron, make sure to put the screws in their respective holes.
    • Once the screws are removed, the bottom plate easily comes off, exposing the inner components of the iron.
  7. Revlon RVIR1008 Disassembly, Remove the barrel shell.: 步骤 7 中的图像 1,1
    • To remove the barrel, simply side the silver outer shell away from the inner heat transfer element.
    • The inner heat transfer element is attached to multiple AC power wires. When removing the barrel shell, make sure the inner heating element is not pulled away from the rest of the iron or the wires may tear off.
  8. Revlon RVIR1008 Disassembly, Remove the top of the handle.: 步骤 8 中的图像 1,2 Revlon RVIR1008 Disassembly, Remove the top of the handle.: 步骤 8 中的图像 2,2
    • Using your hands, slowly pull the inner components away from the top of the handle.
  9. Revlon RVIR1008 Disassembly, Remove the swivel cord.: 步骤 9 中的图像 1,3 Revlon RVIR1008 Disassembly, Remove the swivel cord.: 步骤 9 中的图像 2,3 Revlon RVIR1008 Disassembly, Remove the swivel cord.: 步骤 9 中的图像 3,3
    • Using your hands, slowly pull the cord away from the socket. The cord should easily slide out of the socket.
  10. Revlon RVIR1008 Disassembly, Remove the temperature dials.: 步骤 10 中的图像 1,3 Revlon RVIR1008 Disassembly, Remove the temperature dials.: 步骤 10 中的图像 2,3 Revlon RVIR1008 Disassembly, Remove the temperature dials.: 步骤 10 中的图像 3,3
    • Using two hands, grab each wheel and pull the temperature dials away from the circuit board.
  11. Revlon RVIR1008 Disassembly, You did it!: 步骤 11 中的图像 1,1
    • You have successfully completed the disassembly! Follow these steps in reverse to reassemble your curling iron.
终点
Kelsea
于09/15/15注册
190 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 34
总计 3,371
