跳转到主内容
Revlon One-Step Hair Dryer Setting Dial Replacement
你所需要的
  1. Revlon One-Step Hair Dryer Setting Dial Replacement, Barrel: 步骤 1 中的图像 1,1
    • First, remove the pink panels on each side of the handle in order to access the screws.
    • Use the iFixit opening tool to remove the pink panels.
  2. Revlon One-Step Hair Dryer Setting Dial Replacement: 步骤 2 中的图像 1,3 Revlon One-Step Hair Dryer Setting Dial Replacement: 步骤 2 中的图像 2,3 Revlon One-Step Hair Dryer Setting Dial Replacement: 步骤 2 中的图像 3,3
    • After removing the pink panels, there will be one visible screw on each side of the dryer handle measuring at 11mm.
    • Carefully unscrew both of these screws with a tri-point Y000 screwdriver.
    • Next, completely remove the screws out of the dryer handle.
  3. Revlon One-Step Hair Dryer Setting Dial Replacement: 步骤 3 中的图像 1,3 Revlon One-Step Hair Dryer Setting Dial Replacement: 步骤 3 中的图像 2,3 Revlon One-Step Hair Dryer Setting Dial Replacement: 步骤 3 中的图像 3,3
    • Remove the barrel by twisting and pulling it away from the handle of the dryer.
    • Before attempting to take the barrel off, make sure the dryer powered completely off and is cool to the touch.
  4. Revlon One-Step Hair Dryer Setting Dial Replacement, Cord and Plug: 步骤 4 中的图像 1,2 Revlon One-Step Hair Dryer Setting Dial Replacement, Cord and Plug: 步骤 4 中的图像 2,2
    • Next, slide down the air inlet and the setting dial to reveal the 11mm screws on each side of the handle at the bottom of the hair dryer.
  5. Revlon One-Step Hair Dryer Setting Dial Replacement: 步骤 5 中的图像 1,1
    • There will be one visible screw on each side of the dryer at the bottom of the handle, measuring at 11mm.
    • Store screws in a safe place, you will need them to reassemble the device later.
  6. Revlon One-Step Hair Dryer Setting Dial Replacement: 步骤 6 中的图像 1,1
    • Place the iFixit opening tool along the seams of the handle and pry the two pieces apart.
  7. Revlon One-Step Hair Dryer Setting Dial Replacement: 步骤 7 中的图像 1,3 Revlon One-Step Hair Dryer Setting Dial Replacement: 步骤 7 中的图像 2,3 Revlon One-Step Hair Dryer Setting Dial Replacement: 步骤 7 中的图像 3,3
    • Once you have exposed the inside of the dryer, you will see a clear port at the very end where the cord is connected and plugged into.
    • Now, with your thumb and pointer finger gently pinch the top and bottom of the clear port.
    • Next with your free hand carefully pull the cord out of the port of the dryer handle.
  8. Revlon One-Step Hair Dryer Setting Dial Replacement, Setting Dial: 步骤 8 中的图像 1,1
    • Once the cord is disconnected from the handle, you should be able to slide the dial setting off completely and free it from the cord.
结论
2等其他人完成本指南。
一条评论
Referring to step 4, how do you release the first part with the metal mesh inside from the body
Richard Funnell - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 115
总计 4,997
