跳转到主内容
Revlon One-Step Hair Dryer Cord and Plug Replacement
你所需要的
  1. Revlon One-Step Hair Dryer Cord and Plug Replacement, Barrel: 步骤 1 中的图像 1,1
    • First, remove the pink panels on each side of the handle in order to access the screws.
    • Use the iFixit opening tool to remove the pink panels.
  2. Revlon One-Step Hair Dryer Cord and Plug Replacement: 步骤 2 中的图像 1,3 Revlon One-Step Hair Dryer Cord and Plug Replacement: 步骤 2 中的图像 2,3 Revlon One-Step Hair Dryer Cord and Plug Replacement: 步骤 2 中的图像 3,3
    • After removing the pink panels, there will be one visible screw on each side of the dryer handle measuring at 11mm.
    • Carefully unscrew both of these screws with a tri-point Y000 screwdriver.
    • Next, completely remove the screws out of the dryer handle.
  3. Revlon One-Step Hair Dryer Cord and Plug Replacement: 步骤 3 中的图像 1,3 Revlon One-Step Hair Dryer Cord and Plug Replacement: 步骤 3 中的图像 2,3 Revlon One-Step Hair Dryer Cord and Plug Replacement: 步骤 3 中的图像 3,3
    • Remove the barrel by twisting and pulling it away from the handle of the dryer.
    • Before attempting to take the barrel off, make sure the dryer powered completely off and is cool to the touch.
  4. Revlon One-Step Hair Dryer Cord and Plug Replacement, Cord and Plug: 步骤 4 中的图像 1,2 Revlon One-Step Hair Dryer Cord and Plug Replacement, Cord and Plug: 步骤 4 中的图像 2,2
    • Next, slide down the air inlet and the setting dial to reveal the 11mm screws on each side of the handle at the bottom of the hair dryer.
  5. Revlon One-Step Hair Dryer Cord and Plug Replacement: 步骤 5 中的图像 1,1
    • There will be one visible screw on each side of the dryer at the bottom of the handle, measuring at 11mm.
    • Store screws in a safe place, you will need them to reassemble the device later.
  6. Revlon One-Step Hair Dryer Cord and Plug Replacement: 步骤 6 中的图像 1,1
    • Place the iFixit opening tool along the seams of the handle and pry the two pieces apart.
  7. Revlon One-Step Hair Dryer Cord and Plug Replacement: 步骤 7 中的图像 1,3 Revlon One-Step Hair Dryer Cord and Plug Replacement: 步骤 7 中的图像 2,3 Revlon One-Step Hair Dryer Cord and Plug Replacement: 步骤 7 中的图像 3,3
    • Once you have exposed the inside of the dryer, you will see a clear port at the very end where the cord is connected and plugged into.
    • Now, with your thumb and pointer finger gently pinch the top and bottom of the clear port.
    • Next with your free hand carefully pull the cord out of the port of the dryer handle.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 123
总计 5,222
