跳转到主内容
Revlon One-Step Hair Dryer Barrel Replacement
你所需要的
  1. Revlon One-Step Hair Dryer Barrel Replacement, Barrel: 步骤 1 中的图像 1,1
    • First, remove the pink panels on each side of the handle in order to access the screws.
    • Use the iFixit opening tool to remove the pink panels.
  2. Revlon One-Step Hair Dryer Barrel Replacement: 步骤 2 中的图像 1,3 Revlon One-Step Hair Dryer Barrel Replacement: 步骤 2 中的图像 2,3 Revlon One-Step Hair Dryer Barrel Replacement: 步骤 2 中的图像 3,3
    • After removing the pink panels, there will be one visible screw on each side of the dryer handle measuring at 11mm.
    • Carefully unscrew both of these screws with a tri-point Y000 screwdriver.
    • Next, completely remove the screws out of the dryer handle.
  3. Revlon One-Step Hair Dryer Barrel Replacement: 步骤 3 中的图像 1,3 Revlon One-Step Hair Dryer Barrel Replacement: 步骤 3 中的图像 2,3 Revlon One-Step Hair Dryer Barrel Replacement: 步骤 3 中的图像 3,3
    • Remove the barrel by twisting and pulling it away from the handle of the dryer.
    • Before attempting to take the barrel off, make sure the dryer powered completely off and is cool to the touch.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 34
总计 1,466
