跳转到主内容
Revlon 473 Thermal Cutout Replacement
你所需要的
  1. Revlon 473 Thermal Cutout Replacement, Shell: 步骤 1 中的图像 1,1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Thermal Cutout Replacement: 步骤 2 中的图像 1,1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Thermal Cutout Replacement: 步骤 3 中的图像 1,3 Revlon 473 Thermal Cutout Replacement: 步骤 3 中的图像 2,3 Revlon 473 Thermal Cutout Replacement: 步骤 3 中的图像 3,3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Thermal Cutout Replacement, Thermal Cutout: 步骤 4 中的图像 1,1
    • Locate the thermal cutout under the coils of the heating element.
  5. Revlon 473 Thermal Cutout Replacement: 步骤 5 中的图像 1,1
    • Test the thermal cutout for continuity using the multimeter.
    • Make sure the multimeter is set to 200 ACV and bring the probes toward the thermal cutout.
    • If the numbers on the multimeter continue to change, the circuit is closed and properly functioning.
    • If the multimeter reads a consistent number, the circuit is opened and the thermal cutout needs to be replaced.
  6. Revlon 473 Thermal Cutout Replacement: 步骤 6 中的图像 1,1
    • To replace the thermal cutout, use the spudgers to extract the object.
    • To remove, wedge it back and forth until it comes free.
    • You do not need to take out the gold piece, only the thermal cutout.
  7. Revlon 473 Thermal Cutout Replacement: 步骤 7 中的图像 1,1
    • Replace the old thermal cutout with a new thermal cutout by snapping it into place.
结论
Jessica Leyva
于09/18/12注册
143 声望
创作了5篇指南
团队
Cal Poly, Team 1-5, Propen Fall 2012 Cal Poly, Team 1-5, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,886
