跳转到主内容
加入维修社区 - 创建账户
Revlon 473 Heating Element Replacement
你所需要的
  1. Revlon 473 Heating Element Replacement, Shell: 步骤 1 中的图像 1,1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Heating Element Replacement: 步骤 2 中的图像 1,1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Heating Element Replacement: 步骤 3 中的图像 1,3 Revlon 473 Heating Element Replacement: 步骤 3 中的图像 2,3 Revlon 473 Heating Element Replacement: 步骤 3 中的图像 3,3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Heating Element Replacement, Heating Element: 步骤 4 中的图像 1,1
    • The heating element is the group of tightly coiled bronze wires behind the vent hose as well as the silver coils.
    • Make sure that there are no breaks or debris obstructing the wires of the heating element.
  5. Revlon 473 Heating Element Replacement: 步骤 5 中的图像 1,1
    • To test the heating element, use a digital multimeter.
    • Set the multimeter to 200 under ACV (alternating current voltage).
    • Bring the ends of the multimeter toward the two lead wires.
    • If the circuit between the wires is closed, the numbers on the multimeter should keep changing.
    • If the numbers are not changing, replace the heating element.
    • If the circuit is closed, check the thermal cutout.
结论
Jessica Leyva
于09/18/12注册
143 声望
创作了5篇指南
团队
Cal Poly, Team 1-5, Propen Fall 2012 Cal Poly, Team 1-5, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 43
总计 2,118
