简介
The gaskets and seals of this brewing unit are under much strain and have to be replaced from time to time.
The Nivona brewing unit (brewgroup) is identical with those of other brands, such as Bosch, Siemens or Melitta.
你所需要的
Remove the hose connecting the upper piston and the coffee outlet.
Remove the upper piston.
Remove the Torx T20 screw from the screen of the upper piston.
Take off the cover of the gasket and the gasket.
Replace the gaskets of the upper piston, the coffee outlet and water connector.
Clean thoroughly all parts. Use food-proof silicone grease to lubricate the gaskets.
Apply all steps in reverse order to re-assemble the device.
3等其他人完成本指南。
由衷感谢以下译者:
100%
jana°正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
