跳转到主内容
Reupholstering a Couch Cushion
你所需要的
  1. Reupholstering a Couch Cushion, Couch Upholstery: 步骤 1 中的图像 1,3 Reupholstering a Couch Cushion, Couch Upholstery: 步骤 1 中的图像 2,3 Reupholstering a Couch Cushion, Couch Upholstery: 步骤 1 中的图像 3,3
    • Remove the cushion from the couch. This will easily insure you to get the proper measurements of the cushion.
  2. Reupholstering a Couch Cushion: 步骤 2 中的图像 1,3 Reupholstering a Couch Cushion: 步骤 2 中的图像 2,3 Reupholstering a Couch Cushion: 步骤 2 中的图像 3,3
    • Using a tape measure, measure the height, width, and length the cushion.
  3. Reupholstering a Couch Cushion: 步骤 3 中的图像 1,2 Reupholstering a Couch Cushion: 步骤 3 中的图像 2,2
    • Replace the cushion with a new cushion.
    • In my case, I added a layer of new memory foam on the top and bottom of the existing cushion.
  4. Reupholstering a Couch Cushion: 步骤 4 中的图像 1,1
    • Draw out the measurements on the new fabric.
    • Take the measurements you gathered from Step 2 and measure/draw it on the new fabric to accurately cut the the fabric.
  5. Reupholstering a Couch Cushion: 步骤 5 中的图像 1,2 Reupholstering a Couch Cushion: 步骤 5 中的图像 2,2
    • Cut new fabric along your designated measurement lines.
    • Iron the newly cut fabric to prevent any wrinkles. This will help make for a more smooth and easy process.
  6. Reupholstering a Couch Cushion: 步骤 6 中的图像 1,1
    • Cover the cushion with the fabric
  7. Reupholstering a Couch Cushion: 步骤 7 中的图像 1,2 Reupholstering a Couch Cushion: 步骤 7 中的图像 2,2
    • Staple the fabric onto the cushion so it is secure enough that it will not come loose.
    • Once this step is completed, your cushion is all done and ready to be put back onto your couch!
    • If you would prefer: another way to secure the fabric around the cushion would be the sew it!
  8. Reupholstering a Couch Cushion: 步骤 8 中的图像 1,1
    • Final product!
结论
To reupholster your cushion, follow these instructions:
1. Remove the cushion(s) from the couch.
This will easily insure you to get the proper measurements of the cushion(s).
2. Using a tape measure, measure the height, width, and length of the cushion(s).
3. Replace the cushion with new cushion.
*In my case, I added a layer of new memory foam to the top and bottom of the existing cushion.
4. Draw out the measurements on the new fabric.
5. Cut and iron the new fabric to prevent any wrinkles. *This will help make for a more smooth and easy process.
6. Cover the cushion with the fabric
7. Staple the fabric onto the cushion so it is secure enough that it won’t come loose.
另外一个人完成了本指南。
Tiffany St.Lifer
于01/21/20注册
187 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 98
总计 3,905
