跳转到主内容
Retro-Bit Retro Duo Reset Button/Power Switch Replacement
你所需要的
  1. Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: 步骤 1 中的图像 1,3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: 步骤 1 中的图像 2,3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: 步骤 1 中的图像 3,3
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one, or more, of the screws. Simply remove the it before the screws.
    • Flip the console on its feet and carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not completely remove the top case. There is a small circuit board--which houses two LEDs-- connected to the main circuit board.
  2. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: 步骤 2 中的图像 1,3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: 步骤 2 中的图像 2,3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: 步骤 2 中的图像 3,3
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case.
    • This step allows easy button access and prevents accidental damage.
  3. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: 步骤 3 中的图像 1,3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: 步骤 3 中的图像 2,3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Using your fingers (or precision tweezers), carefully pinch the button tabs and push through to the other side.
    • Make sure you pinch both tabs simultaneously, or the button will not pop out.
结论
If the problem persists after the buttons are replaced, it may be a circuit board issue. If so, please visit our guide for circuit board replacement at Retro-Bit Retro Duo Circuit Board Replacement
Truong Vo
于09/25/17注册
324 声望
创作了3篇指南
团队
USF Tampa, Team S4-G4, Eyestone Fall 2017 USF Tampa, Team S4-G4, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S4G4
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 947
