跳转到主内容
加入维修社区 - 创建账户
Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement
你所需要的
  1. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement, Circuit Board in Controller(s): 步骤 1 中的图像 1,3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement, Circuit Board in Controller(s): 步骤 1 中的图像 2,3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement, Circuit Board in Controller(s): 步骤 1 中的图像 3,3
    • With the controller on its face, remove the five 6 mm Phillips #1 screws.
    • After removing the screws, carefully lift the controller casing .
  2. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: 步骤 2 中的图像 1,3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: 步骤 2 中的图像 2,3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: 步骤 2 中的图像 3,3
    • Pinch the top and bottom of the shoulder buttons and lift them out.
    • Below each shoulder button, there are small elastic pads. To remove them, pinch the pads and slide them out.
    • Removing the elastic pads allows easier circuit board access.
  3. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: 步骤 3 中的图像 1,3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: 步骤 3 中的图像 2,3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: 步骤 3 中的图像 3,3
    • Carefully lift the circuit board from the controller case.
结论
Evelyn
于09/25/17注册
228 声望
创作了2篇指南
团队
USF Tampa, Team S4-G4, Eyestone Fall 2017 USF Tampa, Team S4-G4, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S4G4
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 81
总计 1,348
