跳转到主内容
Retro-Bit Retro Duo Cartridge Doors Replacement
你所需要的
  1. Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: 步骤 1 中的图像 1,3 Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: 步骤 1 中的图像 2,3 Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: 步骤 1 中的图像 3,3
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one or more of the screws. Remove it before the screws.
    • Flip the console on its feet, pinch near the AV/S ports, and carefully lift the top casing.
    • Do not completely remove the top casing. There is a small LED circuit board connected to the main circuit board.
  2. Retro-Bit Retro Duo Cartridge Doors Replacement: 步骤 2 中的图像 1,3 Retro-Bit Retro Duo Cartridge Doors Replacement: 步骤 2 中的图像 2,3 Retro-Bit Retro Duo Cartridge Doors Replacement: 步骤 2 中的图像 3,3
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case and set aside.
  3. Retro-Bit Retro Duo Cartridge Doors Replacement: 步骤 3 中的图像 1,3 Retro-Bit Retro Duo Cartridge Doors Replacement: 步骤 3 中的图像 2,3 Retro-Bit Retro Duo Cartridge Doors Replacement: 步骤 3 中的图像 3,3
    • Remove the eight 10 mm Phillips #0 screws.
    • The cartridge doors are spring-loaded and may pop up.
  4. Retro-Bit Retro Duo Cartridge Doors Replacement: 步骤 4 中的图像 1,2 Retro-Bit Retro Duo Cartridge Doors Replacement: 步骤 4 中的图像 2,2
    • Carefully lift the cartridge door case and set aside.
  5. Retro-Bit Retro Duo Cartridge Doors Replacement: 步骤 5 中的图像 1,2 Retro-Bit Retro Duo Cartridge Doors Replacement: 步骤 5 中的图像 2,2
    • Take the cartridge doors out of the top casing.
    • Keep the correct cartridge doors together. Note the door numbers and position.
    • Doors numbered two and four are for NES cartridges.
    • Doors numbered three are for SNES cartridges.
结论
Truong Vo
于09/25/17注册
320 声望
创作了3篇指南
团队
USF Tampa, Team S4-G4, Eyestone Fall 2017 USF Tampa, Team S4-G4, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S4G4
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 583
