Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
Take care not to damage the cable. If the adhesive is very strong, heat the case directly beneath the cable with an iOpener to soften the adhesive, and then try again.
Disconnect the display cable by gently pulling it straight out of its connector.
Immediately close the retaining flap. Keep it closed throughout your repair.
During reassembly, keep the flap closed while you insert the display cable. Remember to orient the cable so its gold contacts face down, making sure not to crimp or fold it—it'll click into place when it's connected.
Insert one arm of your angled tweezers under the metal neck of the first antenna connector and pry up to disconnect it.
The antenna connectors and sockets are extremely fragile. Be very careful to lift only on the connector, and not on the socket itself. Do not lift under the cable, or put any unnecessary strain on it.
Pry up the second antenna connector to disconnect it.
