跳转到主内容
加入维修社区 - 创建账户
Restroom Sink Replacement
你所需要的
  1. Restroom Sink Replacement, Restroom Sink: 步骤 1 中的图像 1,3 Restroom Sink Replacement, Restroom Sink: 步骤 1 中的图像 2,3 Restroom Sink Replacement, Restroom Sink: 步骤 1 中的图像 3,3
    • Turn off the water source beneath the sink.
    • If the sink is a bit old or rusted, make sure to wipe it with wipes and paper towels.
    • Wear Gloves for better grip of knobs and to prevent spills over your hand or arm.
  2. Restroom Sink Replacement: 步骤 2 中的图像 1,3 Restroom Sink Replacement: 步骤 2 中的图像 2,3 Restroom Sink Replacement: 步骤 2 中的图像 3,3
    • Turn on the knobs on the sink to confirm the water is off and release the remaining water.
    • Always have a container ready when checking for remaining water to catch in.
    • Once you are finished reassuring, you can move onto step 3.
  3. Restroom Sink Replacement: 步骤 3 中的图像 1,3 Restroom Sink Replacement: 步骤 3 中的图像 2,3 Restroom Sink Replacement: 步骤 3 中的图像 3,3
    • Gently loosen the elbow that connects the sink to the pipe leading to the wall with pliers.
    • Use a container to catch any water in the elbow.
    • Don't use too much strength to avoid damage to the wall pipping as you loosen the elbow.
  4. Restroom Sink Replacement: 步骤 4 中的图像 1,3 Restroom Sink Replacement: 步骤 4 中的图像 2,3 Restroom Sink Replacement: 步骤 4 中的图像 3,3
    • With a sharp blade, cut along the old silicon to detach the sink from the cabinet.
    • Use blase with caution to avoid injury to self or damage to the sink.
    • Then detach the hoses from below the sink.
    • Beware, water might be in the hoses as you detach them.
  5. Restroom Sink Replacement: 步骤 5 中的图像 1,3 Restroom Sink Replacement: 步骤 5 中的图像 2,3 Restroom Sink Replacement: 步骤 5 中的图像 3,3
    • When you are done with steps 1 through 4, remove the old sink and replace it with the new one.
    • If your new sink is a newer model, make sure it has the same length and width with a measuring tape.
    • Beware to avoid damage to the sink or cabinet, if it is placed by force.
  6. Restroom Sink Replacement: 步骤 6 中的图像 1,3 Restroom Sink Replacement: 步骤 6 中的图像 2,3 Restroom Sink Replacement: 步骤 6 中的图像 3,3
    • Reconnect the hoses and turn on the water with the knobs under the sink, to make sure it runs smoothly.
    • Apply silicon to seal areas around sink and let it dry.
    • Wait for the silicon to dry before using it.
结论
To conclude, replacing a sink seems like a tedious job. But, any beginner can do it without a plumber's assistance. Therefore, saving lots of money on labor.
Robertcastillo
于03/21/23注册
142 声望
撰写一个指南
团队
CSU Los Angeles, Team 1-24, Briggs Spring 2023 CSU Los Angeles, Team 1-24, Briggs Spring 2023 的会员
CSULA-BRIGGS-S23S1G24
1 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 52
总计 356
