跳转到主内容
修复你的物品
维修的权力
商店
简介
This is a quick and simple guide on how to remove your old restroom ceiling fan. The replacement part for this guide can be found here.
  1. Turn off the breaker to the bathroom light in your home's circuit panel. If the fuse is not labelled, you can turn the bathroom fan on and turn off fuses until the bathroom fan is turned off. Be sure to turn off the bathroom fan before starting the fix even though the fuse may be turned off.
    • Turn off the breaker to the bathroom light in your home's circuit panel.
    • If the fuse is not labelled, you can turn the bathroom fan on and turn off fuses until the bathroom fan is turned off. Be sure to turn off the bathroom fan before starting the fix even though the fuse may be turned off.
  2. Carefully remove the  grill cover on the unit by grasping the outer edges and pulling downward, toward the floor. Carefully remove the  grill cover on the unit by grasping the outer edges and pulling downward, toward the floor.
    • Carefully remove the grill cover on the unit by grasping the outer edges and pulling downward, toward the floor.
  3. Pinch the mounting wires toward each other and pull downward. Do this on both sides. Dust accumulation should be expected. You may want to wear a mask and eye protection to avoid falling dust.
    • Pinch the mounting wires toward each other and pull downward. Do this on both sides.
    • Dust accumulation should be expected. You may want to wear a mask and eye protection to avoid falling dust.
  4. Unplug the unit. Using a circuit tester, confirm that there is no power running through the fan's circuit. Unplug the unit. Using a circuit tester, confirm that there is no power running through the fan's circuit.
    • Unplug the unit. Using a circuit tester, confirm that there is no power running through the fan's circuit.
  5. Remove the entire fan housing assembly from the ceiling.
    • Remove the entire fan housing assembly from the ceiling.
    • Be careful that the outer edge of the assembly does not make contact with the drywall as not to damage it.
    • Do not touch the ceiling with hands to avoid leaving fingerprints.
结论
另外一个人完成了本指南。
Kolton
于2020年04月29日注册
121 信誉积分
撰写一个指南
团队
UW Tacoma, Team S1-G39, Cardinal Spring 2020 UW Tacoma, Team S1-G39, Cardinal Spring 2020 的会员
UWT-CARDINAL-S20S1G39
1 名成员
创作了1篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 85
