跳转到主内容
Respironics REMstar Plus M Series Power Supply Circuit board Replacement
你所需要的
  1. Respironics REMstar Plus M Series Power Supply Circuit board Replacement, Power Supply Circuit board: 步骤 1 中的图像 1,3 Respironics REMstar Plus M Series Power Supply Circuit board Replacement, Power Supply Circuit board: 步骤 1 中的图像 2,3 Respironics REMstar Plus M Series Power Supply Circuit board Replacement, Power Supply Circuit board: 步骤 1 中的图像 3,3
    • Place the device face down.
    • Use a T15 Torx screwdriver to remove the six screws in the base plate.
    • Lift the base plate off of the device.
  2. Respironics REMstar Plus M Series Power Supply Circuit board Replacement: 步骤 2 中的图像 1,3 Respironics REMstar Plus M Series Power Supply Circuit board Replacement: 步骤 2 中的图像 2,3 Respironics REMstar Plus M Series Power Supply Circuit board Replacement: 步骤 2 中的图像 3,3
    • Flip the circuit board over to the right.
    • Gently pull the ribbon cable outward to disconnect it from the circuit board.
  3. Respironics REMstar Plus M Series Power Supply Circuit board Replacement: 步骤 3 中的图像 1,2 Respironics REMstar Plus M Series Power Supply Circuit board Replacement: 步骤 3 中的图像 2,2
    • Disconnect the red 3-wire plug at the top left of the board and the white 4-wire plug at the bottom left.
    • Remove the circuit board.
结论
2条评论
My unit stops working in the middle of the night, then beeps, & blue light flashes. Will replacing this board fix this, and where can I get one?
mert454 - 回复
Where to find a power supply circuit board for my Remstar plus m series which just blinks blue lights. dledes@shaw.ca
David Edes - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 986
