跳转到主内容
Respawn RSP-110 Gaming Chair Gas Cylinder Replacement
你所需要的
  1. Respawn RSP-110 Gaming Chair Gas Cylinder Replacement, Gas Cylinder: 步骤 1 中的图像 1,1
    • Below the seat, push the lift lever up to extend the chair to its full capacity.
    • To the left of the lift lever, push the lock lever up to ensure the backrest is vertical.
  2. Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: 步骤 2 中的图像 1,2 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: 步骤 2 中的图像 2,2
    • Lay the chair horizontally with its legs in their open position.
  3. Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: 步骤 3 中的图像 1,2 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: 步骤 3 中的图像 2,2
    • Optional: Place a towel over the bottom end of the cylinder to avoid damaging it in the next step.
  4. Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: 步骤 4 中的图像 1,3 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: 步骤 4 中的图像 2,3 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: 步骤 4 中的图像 3,3
    • Use rubber mallet to strike the bottom of the cylinder firmly to dislodge it.
    • If the cylinder remains lodged, continue striking it with the rubber mallet until it dislodges.
    • Exercise caution to prevent damage and avoid injury while dislodging the cylinder.
  5. Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: 步骤 5 中的图像 1,3 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: 步骤 5 中的图像 2,3 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: 步骤 5 中的图像 3,3
    • Using the pipe wrench/vise-grip, twist the cylinder out of place.
    • You will need to twist clockwise or counter-clockwise repeatedly until the cylinder releases.
  6. Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: 步骤 6 中的图像 1,3 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: 步骤 6 中的图像 2,3 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: 步骤 6 中的图像 3,3
    • Get your new gas cylinder.
    • Make sure that the plastic cylinder cover is around the cylinder.
    • Attach the cylinder to the underside of the seat, and twist counterclockwise.
  7. Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: 步骤 7 中的图像 1,2 Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: 步骤 7 中的图像 2,2
    • Place the bottom of the cylinder into the chair base and twist to lock it just enough to safely stand it upright
    • If the cylinder is not secure enough, the chair may fall apart.
  8. Respawn RSP-110 Gaming Chair Gas Cylinder Replacement: 步骤 8 中的图像 1,1
    • Stand the chair upright.
    • Place your knee on the seat and hold the armrests.
    • Apply pressure on the middle of the seat to ensure that the cylinder is locked in place.
结论
You've successfully replaced the gas cylinder on your chair!
Luca Caniglia
于04/15/24注册
157 声望
撰写一个指南
团队
UC Davis, Team 2-4, Morris Spring 2024 UC Davis, Team 2-4, Morris Spring 2024 的会员
UCD-MORRIS-S24S2G4
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 22
过去 30 天: 82
总计 866
