跳转到主内容
Resetting the Tidal Volume Alarm in Settings
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
  1. Resetting the Tidal Volume Alarm in Settings, Resetting the Tidal Volume Alarm in Settings: 步骤 1 中的图像 1,1
    • When the alarm is going off there is an alarm indication banner on the upper right corner of the screen.
    • Pull out that banner.
    • This is the warning banner.
    • The warning banner color indicates the severity of the situation, from red to yellow-blinking to yellow.
  2. Resetting the Tidal Volume Alarm in Settings: 步骤 2 中的图像 1,1
    • Select the hotlink to the alarm settings screen on the selection “Go to Alarm Setting”.
    • You can also always select the alarm button on the panel that is in the shape of a bell.
    • The hotlink to select.
  3. Resetting the Tidal Volume Alarm in Settings: 步骤 3 中的图像 1,1
    • Similar to the picture of the alarm indication on the Low Mandatory Tidal Volume parameter, there can be an indication on Spontaneous Tidal Volume that is lit the same color as the degree of the alarm.
    • Select this parameter that is lit.
    • Use the mechanical knob to adjust the parameter.
    • If these steps do not turn off the alarm, then there is a disconnect on the ventilator. Make sure everything is attached properly before starting over on these steps.
终点
另外一个人完成了本指南。
Liam Singh
于04/09/20注册
127 声望
撰写一个指南
团队
Cal Poly, Team S11-G14, Paton Spring 2020 Cal Poly, Team S11-G14, Paton Spring 2020 的会员
CPSU-PATON-S20S11G14
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 470
