跳转到主内容
加入维修社区 - 创建账户
Resetting the Clock
    1. Resetting the Clock, Resetting the Clock: 步骤 1 中的图像 1,1
      • Locate the buttons named "SET", "SKIP", "VOLUME -", and "VOLUME +", which are situated on the top portion of the Nextplay NP109CR.
      询问修复机器人
      添加评论
    2. Resetting the Clock: 步骤 2 中的图像 1,2 Resetting the Clock: 步骤 2 中的图像 2,2
      • Press the "SET" button, the first button from the left in the row located behind the pink snooze bar, three (3) times until the clock display is flashing.
      询问修复机器人
      添加评论
    3. Resetting the Clock: 步骤 3 中的图像 1,1
      • Press the "SKIP" button with the two triangles next to it pointing to the right to advance the hour.
      询问修复机器人
      添加评论
    4. Resetting the Clock: 步骤 4 中的图像 1,1
      • Press the "SKIP" button with the two triangles pointing to the left to retreat the hour.
      询问修复机器人
      添加评论
    5. Resetting the Clock: 步骤 5 中的图像 1,1
      • Press the "VOLUME +" button to advance the minutes forward.
      询问修复机器人
      添加评论
    6. Resetting the Clock: 步骤 6 中的图像 1,1
      • Press the "VOLUME -" button to decrease the minutes.
      询问修复机器人
      添加评论
结论
Once the desired time has been set, the display will continue flashing for about five (5) seconds. When the clock has stopped flashing the clock has been reset successfully. Setting the clock can be very useful when traveling or when living in an area with frequent power outages.
取消:我没有完成这个指南。
Jacob Aube
于09/24/12注册
1 声望
撰写一个指南
团队
Cal Poly, Team 7-50, Forte Fall 2012 Cal Poly, Team 7-50, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G50
5 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 23
总计 1,835
