跳转到主内容
加入维修社区 - 创建账户
Rescue Your UGGs: A Guide to Removing Water Stains on UGGs
你所需要的
  1. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Brush off dirt: 步骤 1 中的图像 1,2 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Brush off dirt: 步骤 1 中的图像 2,2
    • Gently brush the exterior of the boots with a soft suede brush. 
    询问修复机器人
    添加评论
  2. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Dampen boots: 步骤 2 中的图像 1,2 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Dampen boots: 步骤 2 中的图像 2,2
    • Use the sponge to lightly dampen the outer surface of your boots with cold water (do NOT soak as it will damage fabric).
    询问修复机器人
    添加评论
  3. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Cleaning Boots: 步骤 3 中的图像 1,2 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Cleaning Boots: 步骤 3 中的图像 2,2
    • Apply a small amount of the sheepskin cleaner and conditioner on a wet sponge and gently rub the problem areas on the exterior of the UGG boots. ​ Note: Scrubbing vigorously can cause damage
    询问修复机器人
    添加评论
  4. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Stuff for Shape: 步骤 4 中的图像 1,2 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Stuff for Shape: 步骤 4 中的图像 2,2
    • Stuff newspaper or paper towels into the boots to help maintain their shape. 
    询问修复机器人
    添加评论
  5. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Air Dry: 步骤 5 中的图像 1,1
    • Place the UGG boots in a dry and well-ventilated area away from direct sunlight to dry (Do not use heat to speed up the process).
    询问修复机器人
    添加评论
  6. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Brush: 步骤 6 中的图像 1,2 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Brush: 步骤 6 中的图像 2,2
    • When the boots are dry gently brush the exterior with a soft suede brush.  
    询问修复机器人
    添加评论
  7. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Remove fillers: 步骤 7 中的图像 1,3 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Remove fillers: 步骤 7 中的图像 2,3 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Remove fillers: 步骤 7 中的图像 3,3
    • Remove the newspaper or paper towels from the boots.
    询问修复机器人
    添加评论
终点
取消:我没有完成这个指南。
Lara Van Heerden
于11/27/23注册
145 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 98
总计 6,645
