简介
This guide will show you how to replace the motherboard in the ResMed VPAP Auto 25 medical ventilator. The display is incorporated into the board, so by replacing the motherboard, you will either need to transfer your old display onto the new board, or find a replacement with a board already installed. The motherboard is responsible for managing the volume and pressure of medical gasses delivered to the patient, so it’s critical that it is functioning correctly when in use.
你所需要的
Remove the four 26.7 mm T3 Torx screws from the bottom side of the ResMed VPAP Auto 25.
一条评论
Where can I purchase a motherboard and or a power circuit board for the S8 Vpap? My Vpap stopped working and I could fix it if I could find the parts - even used. I know it’s a power issue as the machine won’t even turn on. I took mine apart and I see a mother board and a power circuit board where the power cord attaches. Any help would be appreciated. Thanks
