跳转到主内容
ResMed VPAP Auto 25 Circuit Board Replacement
你所需要的
  1. ResMed VPAP Auto 25 Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 1,3 ResMed VPAP Auto 25 Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 2,3 ResMed VPAP Auto 25 Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 3,3
    • Remove the four 26.7 mm T3 Torx screws from the bottom side of the ResMed VPAP Auto 25.
  2. ResMed VPAP Auto 25 Circuit Board Replacement: 步骤 2 中的图像 1,3 ResMed VPAP Auto 25 Circuit Board Replacement: 步骤 2 中的图像 2,3 ResMed VPAP Auto 25 Circuit Board Replacement: 步骤 2 中的图像 3,3
    • Flip the device over.
    • Pry the outermost plastic cover off with the metal spudger until the cover is loose and able to be removed.
  3. ResMed VPAP Auto 25 Circuit Board Replacement: 步骤 3 中的图像 1,2 ResMed VPAP Auto 25 Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Pull off the front cover to reveal the internal components.
  4. ResMed VPAP Auto 25 Circuit Board Replacement: 步骤 4 中的图像 1,3 ResMed VPAP Auto 25 Circuit Board Replacement: 步骤 4 中的图像 2,3 ResMed VPAP Auto 25 Circuit Board Replacement: 步骤 4 中的图像 3,3
    • Loosen the motherboard from the rubber dowels holding it in place and unplug the screen components.
  5. ResMed VPAP Auto 25 Circuit Board Replacement: 步骤 5 中的图像 1,3 ResMed VPAP Auto 25 Circuit Board Replacement: 步骤 5 中的图像 2,3 ResMed VPAP Auto 25 Circuit Board Replacement: 步骤 5 中的图像 3,3
    • Remove the three 26.7 mm T3 Torx screws from the now visible rubber fan motor cover.
    • Lift off the rubber fan motor cover, revealing the fan motor.
  6. ResMed VPAP Auto 25 Circuit Board Replacement: 步骤 6 中的图像 1,3 ResMed VPAP Auto 25 Circuit Board Replacement: 步骤 6 中的图像 2,3 ResMed VPAP Auto 25 Circuit Board Replacement: 步骤 6 中的图像 3,3
    • Remove the fan motor unit from its housing.
    • Remove the three 26.7 mm screws securing the motor housing to the bottom piece with a T3 Torx screwdriver.
  7. ResMed VPAP Auto 25 Circuit Board Replacement: 步骤 7 中的图像 1,3 ResMed VPAP Auto 25 Circuit Board Replacement: 步骤 7 中的图像 2,3 ResMed VPAP Auto 25 Circuit Board Replacement: 步骤 7 中的图像 3,3
    • Pull out the fan motor housing from the bottom cover, revealing a foam insulation pad and the circuit board.
    • Slide the circuit board out of its plastic grooves in the bottom cover to retrieve the desired component.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 231
