跳转到主内容
ResMed S9 VPAP Auto Inner and Outer Filters Replacement
你所需要的
  1. ResMed S9 VPAP Auto Inner and Outer Filters Replacement, Inner and Outer Filters: 步骤 1 中的图像 1,2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement, Inner and Outer Filters: 步骤 1 中的图像 2,2
    • Lift up on the lip of the translucent plastic filter cover on the bottom of the device.
    • Peel back the old filter and replace it with the new one.
  2. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: 步骤 2 中的图像 1,2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: 步骤 2 中的图像 2,2
    • To access the internal filter of the ResMed S9 VPAP Auto, flip the device upside down.
    • Use a T3 Torx screwdriver to remove the screw in the corner.
    • Each screw in this guide is a 1.2 mm Torx T3.
  3. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: 步骤 3 中的图像 1,2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: 步骤 3 中的图像 2,2
    • Use a spudger to pry off the back panel.
  4. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: 步骤 4 中的图像 1,2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: 步骤 4 中的图像 2,2
    • Use the spudger to pry off the front panel.
    • If you are having difficulty, press the two hooks to open that side of the device.
    • Remove to expose the control panel.
  5. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: 步骤 5 中的图像 1,1
    • Remove the two screws on the circuit board with a T3 Torx screwdriver.
  6. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: 步骤 6 中的图像 1,3 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: 步骤 6 中的图像 2,3 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the plug connecting the red, orange, and black wires to the circuit board.
    • The plug in the top right corner is accessed through the bottom of the device.
    • Flip the circuit board upside down and use the tweezers to squeeze the plastic release underneath the remaining plug.
    • The circuit board will then lift right off, exposing the interior of the machine.
  7. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: 步骤 7 中的图像 1,2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: 步骤 7 中的图像 2,2
    • Remove the five screws from the frame with a T3 Torx screwdriver.
    • Lift off the plastic frame to expose the filter housing.
  8. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: 步骤 8 中的图像 1,2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: 步骤 8 中的图像 2,2
    • Remove the silicone and the blower to expose the filters.
    • Remove and replace the foam filters.
结论
另外一个人完成了本指南。
一条评论
where can I purchase the foam filters?
Francis - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 27
总计 896
