跳转到主内容
ResMed AirSense 10 Top Cover Replacement
医疗设备
ifixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
  1. ResMed AirSense 10 Top Cover Replacement, Top Cover: 步骤 1 中的图像 1,2 ResMed AirSense 10 Top Cover Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Remove the water tub by gently pulling it out.
  2. ResMed AirSense 10 Top Cover Replacement: 步骤 2 中的图像 1,3 ResMed AirSense 10 Top Cover Replacement: 步骤 2 中的图像 2,3 ResMed AirSense 10 Top Cover Replacement: 步骤 2 中的图像 3,3
    • Pry off the face plate by using your finger or an opening tool.
    • Use a moderate amount of force when prying open.
    • Remove the face plate from the top cover.
    • There will be a clicking sound on either side of the divot when assembling and disassembling.
  3. ResMed AirSense 10 Top Cover Replacement: 步骤 3 中的图像 1,2 ResMed AirSense 10 Top Cover Replacement: 步骤 3 中的图像 2,2
    • Unscrew and remove the two 11.8 mm TR10 Torx screws that were revealed from the face plate being removed.
  4. ResMed AirSense 10 Top Cover Replacement: 步骤 4 中的图像 1,2 ResMed AirSense 10 Top Cover Replacement: 步骤 4 中的图像 2,2
    • Unscrew and remove the two 11.8 mm TR10 Torx screws from the bottom of the device.
  5. ResMed AirSense 10 Top Cover Replacement: 步骤 5 中的图像 1,3 ResMed AirSense 10 Top Cover Replacement: 步骤 5 中的图像 2,3 ResMed AirSense 10 Top Cover Replacement: 步骤 5 中的图像 3,3
    • Remove the top cover from the rest of the device.
结论
另外一个人完成了本指南。
一条评论
What if the dial button isn't working ?
Katsafrass - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 23
总计 664
