跳转到主内容
Replacing the Slider on a Coil Zipper
你所需要的
视频概述
  1. Replacing the Slider on a Coil Zipper, Coil Zipper Slider: 步骤 1 中的图像 1,3 Replacing the Slider on a Coil Zipper, Coil Zipper Slider: 步骤 1 中的图像 2,3 Replacing the Slider on a Coil Zipper, Coil Zipper Slider: 步骤 1 中的图像 3,3
    • Locate the top of the zipper on the side with the slider.
    • Peel back any fabric that is covering the zipper stop.
  2. Replacing the Slider on a Coil Zipper: 步骤 2 中的图像 1,2 Replacing the Slider on a Coil Zipper: 步骤 2 中的图像 2,2
    • Use end nippers to cut the stop.
    • Be sure to only cut the plastic or metal stop. You do not want to damage the webbing behind the zipper.
  3. Replacing the Slider on a Coil Zipper: 步骤 3 中的图像 1,1
    • Carefully remove any remaining pieces of the stop using tweezers.
  4. Replacing the Slider on a Coil Zipper: 步骤 4 中的图像 1,3 Replacing the Slider on a Coil Zipper: 步骤 4 中的图像 2,3 Replacing the Slider on a Coil Zipper: 步骤 4 中的图像 3,3
    • Slide the damaged zipper slider up and off of the zipper.
  5. Replacing the Slider on a Coil Zipper: 步骤 5 中的图像 1,2 Replacing the Slider on a Coil Zipper: 步骤 5 中的图像 2,2
    • Slide the replacement slider onto the zipper.
    • You may need to tug a little to get it past where the old stop was.
    • Make sure that your zipper slider is facing the correct way (right-side up) when you place it onto the zipper.
  6. Replacing the Slider on a Coil Zipper: 步骤 6 中的图像 1,2 Replacing the Slider on a Coil Zipper: 步骤 6 中的图像 2,2
    • Grab a new zipper stop.
    • Insert the teeth into the webbing in the same place where the old stop was located.
  7. Replacing the Slider on a Coil Zipper: 步骤 7 中的图像 1,3 Replacing the Slider on a Coil Zipper: 步骤 7 中的图像 2,3 Replacing the Slider on a Coil Zipper: 步骤 7 中的图像 3,3
    • Use pliers to bend the metal top of the zipper stop around the edge of the webbing, poking the single tooth on the stop through the backside of the webbing.
    • Crimp the stop into place.
终点
19等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
89,014 声望
创作了131篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
11条评论
Where do I get the zipper stop????
Jason Heimink - 回复
How do you find the size slider(in my case 5 millimetres) and also the right size teeth that will fit into the zipper.
bbehrhorst - 回复
I used this Guide to replace the zipper slide on my wife's favorite Disney fleece jacket. I purchased my slide and the stop online. Since I'm not sure about the rules on posting vendor's info, I will say GOOGLE "nylon coil zipper slide". You can have your "zippershipped" right to your door.
kasten39828 - 回复
AWESOME! Thanks for the pointers - I’m ready for tomorrow’s powder day!!!!
Jenny - 回复
Great now how ! thank’s :)
Robert Fyfe - 回复
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 141
过去 30 天: 566
总计 98,712
