跳转到主内容
Replacing the Metal Plate Holding the Leg of an Ironing Board
你所需要的
  1. Replacing the Metal Plate Holding the Leg of an Ironing Board, Metal plate holding the leg of the ironing board: 步骤 1 中的图像 1,1
    • Place the ironing board face down on a flat, stable surface.
  2. Replacing the Metal Plate Holding the Leg of an Ironing Board: 步骤 2 中的图像 1,1
    • Unscrew and remove the broken metal plate.
  3. Replacing the Metal Plate Holding the Leg of an Ironing Board: 步骤 3 中的图像 1,1
    • Cut the metal sheet into an appropriate size.
    • Use cut proof gloves for protection
  4. Replacing the Metal Plate Holding the Leg of an Ironing Board: 步骤 4 中的图像 1,1
    • Using a 1/8" drill bit, drill four holes on each corner where the screws will be placed.
  5. Replacing the Metal Plate Holding the Leg of an Ironing Board: 步骤 5 中的图像 1,1
    • On the corner of a flat edge, use a mallet to shape the metal sheet.
    • Keep your hand at a distance from the mallet to avoid hitting your fingers.
  6. Replacing the Metal Plate Holding the Leg of an Ironing Board: 步骤 6 中的图像 1,1
    • Using a screwdriver, screw on the new plate with the #10-32 x 3/8" pan-headed screws.
  7. Replacing the Metal Plate Holding the Leg of an Ironing Board: 步骤 7 中的图像 1,2 Replacing the Metal Plate Holding the Leg of an Ironing Board: 步骤 7 中的图像 2,2
    • Finish repairing the iron board!
结论
5等其他人完成本指南。
Nina Youn
于10/26/18注册
211 声望
撰写一个指南
团队
UC Davis, Team S2-G1, Bender Fall 2018 UC Davis, Team S2-G1, Bender Fall 2018 的会员
UCD-BENDER-F18S2G1
4 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 55
总计 2,887
