当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Turn the device upside down and then locate the battery latch near the front of the device.
Slide the latch to the left to release the battery.
Continue holding the latch then gently pull the battery out of the device.
Place the battery in a safe location.
Locate the CD-ROM Drive latch.
Slide the latch to the right to release the CD ROM drive.
Continue holding the latch then gently pull the CD-ROM Drive out of the device.
Place the CD ROM drive in a safe location.
Locate the speaker cover.
Press firmly on each end of the speaker cover and slide it to the left.
Gently lift the speaker cover to remove it.
Lift the keyboard up from the back using a spudger(wedge side).
Gently lift the keyboard until only the ribbon cable remains attached.
Tilt the keyboard away from the screen.
Locate the six screws that secure the heatsink.
Remove the six screws from the heatsink using the Philips #1 screwdriver.
Lift the heatsink from the side closest to the laptop screen.
Remove the heatsink.
Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
Detach the ribbon cable.
Remove the keyboard.
Identify the right and left monitor end caps.
Pry off the end caps by putting a spudger between the monitor hinge and the end cap and prying outwards.
Once the end cap has been loosened by the spudger, pull outwards on the end caps.
Completely remove both end caps.
Identify the 4 total screw under the end caps (2 under each end cap).
The two outside 16mm long screws
The two inside 5.4mm long screws
Lay the monitor all the way back.
Remove the 4 screws using the Phillips #0 screwdriver.
Identify the center cap of the monitor.
Pry the center cap off by placing the spudger between the hinge and the center cap and prying upwards.
Detach the center cap completely.
Identify the one 12.6mm long screw under the center cap.
Remove the center screw with a Phillips #0 screwdriver.
Lift upwards on the metal cover under the screw.
Completely remove the metal cover.
Identify where the left and right monitor cords are attached to the logic board
The base of the left monitor cord
The base of the right monitor cord
To detach the left monitor cord grab the left monitor cord at the base of the cord and pull vertically up.
Completely detach the left monitor cord from the logic board.
To detach the right monitor cord grab the right monitor cord at the base of the cord and pull vertically up.
Completely detach the right monitor cord from the logic board.
Completely remove the monitor from the computer.
取消:我没有完成这个指南。
5等其他人完成本指南。
与4其他贡献者
于04/01/11注册
187 声望
撰写一个指南
徽章: 8
+ 5更多徽章
CPSU-FORTE-S11S10G39
5 名成员
创作了6篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 4,147
