跳转到主内容
加入维修社区 - 创建账户
Replacing the Macintosh PowerBook 1400c Monitor
你所需要的
  1. Replacing the Macintosh PowerBook 1400c Monitor, Battery: 步骤 1 中的图像 1,1
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 2 中的图像 1,1
    • Slide the latch to the left to release the battery.
  3. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 3 中的图像 1,1
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Replacing the Macintosh PowerBook 1400c Monitor, CD-ROM Drive: 步骤 4 中的图像 1,1
    • Locate the CD-ROM Drive latch.
  5. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 5 中的图像 1,1
    • Slide the latch to the right to release the CD ROM drive.
  6. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 6 中的图像 1,1
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Replacing the Macintosh PowerBook 1400c Monitor, Keyboard: 步骤 7 中的图像 1,1
    • Locate the speaker cover.
  8. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 8 中的图像 1,1
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 9 中的图像 1,1
    • Gently lift the speaker cover to remove it.
  10. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 10 中的图像 1,1
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 11 中的图像 1,1
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 12 中的图像 1,1
    • Tilt the keyboard away from the screen.
  13. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 13 中的图像 1,1
    • Locate the six screws that secure the heatsink.
  14. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 14 中的图像 1,1
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 15 中的图像 1,1
    • Lift the heatsink from the side closest to the laptop screen.
  16. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 16 中的图像 1,1
    • Remove the heatsink.
  17. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 17 中的图像 1,1
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 18 中的图像 1,1
    • Detach the ribbon cable.
  19. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 19 中的图像 1,1
    • Remove the keyboard.
  20. Replacing the Macintosh PowerBook 1400c Monitor, Monitor: 步骤 20 中的图像 1,1
    • Identify the right and left monitor end caps.
  21. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 21 中的图像 1,1
    • Pry off the end caps by putting a spudger between the monitor hinge and the end cap and prying outwards.
  22. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 22 中的图像 1,1
    • Once the end cap has been loosened by the spudger, pull outwards on the end caps.
  23. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 23 中的图像 1,1
    • Completely remove both end caps.
  24. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 24 中的图像 1,1
    • Identify the 4 total screw under the end caps (2 under each end cap).
    • The two outside 16mm long screws
    • The two inside 5.4mm long screws
  25. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 25 中的图像 1,1
    • Lay the monitor all the way back.
  26. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 26 中的图像 1,1
    • Remove the 4 screws using the Phillips #0 screwdriver.
  27. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 27 中的图像 1,1
    • Identify the center cap of the monitor.
  28. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 28 中的图像 1,1
    • Pry the center cap off by placing the spudger between the hinge and the center cap and prying upwards.
  29. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 29 中的图像 1,1
    • Detach the center cap completely.
  30. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 30 中的图像 1,1
    • Identify the one 12.6mm long screw under the center cap.
  31. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 31 中的图像 1,1
    • Remove the center screw with a Phillips #0 screwdriver.
  32. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 32 中的图像 1,1
    • Lift upwards on the metal cover under the screw.
  33. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 33 中的图像 1,1
    • Completely remove the metal cover.
  34. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 34 中的图像 1,1
    • Identify where the left and right monitor cords are attached to the logic board
    • The base of the left monitor cord
    • The base of the right monitor cord
  35. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 35 中的图像 1,1
    • To detach the left monitor cord grab the left monitor cord at the base of the cord and pull vertically up.
  36. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 36 中的图像 1,1
    • Completely detach the left monitor cord from the logic board.
  37. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 37 中的图像 1,1
    • To detach the right monitor cord grab the right monitor cord at the base of the cord and pull vertically up.
  38. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 38 中的图像 1,1
    • Completely detach the right monitor cord from the logic board.
  39. Replacing the Macintosh PowerBook 1400c Monitor: 步骤 39 中的图像 1,1
    • Completely remove the monitor from the computer.
结论
Once the monitor has been removed, to attach the new monitor follow these instructions in reverse order.
7等其他人完成本指南。
Taylor Chris
于04/01/11注册
241 声望
撰写一个指南
团队
Cal Poly, Team 10-39, Forte Spring 2011 Cal Poly, Team 10-39, Forte Spring 2011 的会员
CPSU-FORTE-S11S10G39
5 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 45
总计 5,002
