跳转到主内容
Replacing strings on an All American Bass
你所需要的
  1. Replacing strings on an All American Bass, Loosen the tuners. By twisting the peg clockwise.: 步骤 1 中的图像 1,1
    • Caution: Be careful when working on tensioned strings. Wear protective gear (eyewear, gloves) if possible.
    • Loosen by clockwise.
  2. Replacing strings on an All American Bass, Pull the G-string (the string with the highest pitch) from the peg.: 步骤 2 中的图像 1,1
    • Can be different per bass.
  3. Replacing strings on an All American Bass, Pull the string from the bridge.: 步骤 3 中的图像 1,1
    • Pull through the hole near the spring.
  4. Replacing strings on an All American Bass, Count the rivets on the old string to ascertain how many twists are needed.: 步骤 4 中的图像 1,1
    • This can be done by counting the rivets in old string.
  5. Replacing strings on an All American Bass, Thread the new strings through the bridge over the groove.: 步骤 5 中的图像 1,1
    • Reverse Step 4.
  6. Replacing strings on an All American Bass, Pull the string up to the tuner head and place it in-to the hole.: 步骤 6 中的图像 1,1
    • CAUTION: Can lead to string snapping and hurting one self.
  7. Replacing strings on an All American Bass, Wrap the string around the tuner peg counter-clockwise.: 步骤 7 中的图像 1,1
  8. Replacing strings on an All American Bass, Tighten the string by twisting the peg counter-clockwise.: 步骤 8 中的图像 1,1
  9. Replacing strings on an All American Bass, Hold the end of the tuner and turn the peg until the bass has been suitably tuned.: 步骤 9 中的图像 1,1
    • Use a phone tuner or regular guitar tuner.
  10. Replacing strings on an All American Bass, Repeat steps 1-9 for all re-maining strings.: 步骤 10 中的图像 1,1
    • You're Done!
结论
Your bass should now be restrung correctly and ready to rock out.
另外一个人完成了本指南。
Jeffrey Baston
于10/26/15注册
1 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 178
