跳转到主内容
Replacing an LED Light Fixture
你所需要的
  1. Replacing an LED Light Fixture, LED Light Fixture: 步骤 1 中的图像 1,3 Replacing an LED Light Fixture, LED Light Fixture: 步骤 1 中的图像 2,3 Replacing an LED Light Fixture, LED Light Fixture: 步骤 1 中的图像 3,3
    • Set up a ladder under the light fixture, and remove the three thumb screws holding up the fixture's cover.
    • Hold the light cover with your free hand while you unscrew the last two screws.
  2. Replacing an LED Light Fixture: 步骤 2 中的图像 1,2 Replacing an LED Light Fixture: 步骤 2 中的图像 2,2
    • Do not remove the base of the light fixture.
    • Check that the light fixture is receiving power with a voltage detector pen.
    • If the light of the voltage detector turns from green to red and makes a loud noise, that means that voltage is still present. Do not proceed with repair until there is no current running.
  3. Replacing an LED Light Fixture: 步骤 3 中的图像 1,3 Replacing an LED Light Fixture: 步骤 3 中的图像 2,3 Replacing an LED Light Fixture: 步骤 3 中的图像 3,3
    • Locate the breaker to your house/unit and identify the switch which provides power to the light fixture.
    • Flip the switch on the breaker to the right to turn off the power to the light fixture.
    • Go back to the light fixture, and check if it is still receiving power with the voltage detector.
    • The voltage detector should remain green when placed near the electrical line connected to the light fixture.
  4. Replacing an LED Light Fixture: 步骤 4 中的图像 1,3 Replacing an LED Light Fixture: 步骤 4 中的图像 2,3 Replacing an LED Light Fixture: 步骤 4 中的图像 3,3
    • Begin unscrewing the base of the light fixture from the ceiling.
  5. Replacing an LED Light Fixture: 步骤 5 中的图像 1,3 Replacing an LED Light Fixture: 步骤 5 中的图像 2,3 Replacing an LED Light Fixture: 步骤 5 中的图像 3,3
    • Once enough screws are removed from the base of the light fixture, hold the center of the base with your free hand so it doesn't fall down on its own.
  6. Replacing an LED Light Fixture: 步骤 6 中的图像 1,2 Replacing an LED Light Fixture: 步骤 6 中的图像 2,2
    • While still holding the base of the light fixture, check if the exposed wires are still unpowered with the voltage detector.
    • The voltage detector should remain green when placed near these exposed wires.
  7. Replacing an LED Light Fixture: 步骤 7 中的图像 1,2 Replacing an LED Light Fixture: 步骤 7 中的图像 2,2
    • Unscrew the screw attached to the metal bracket by twisting the manual Phillips screwdriver until the screw falls off.
  8. Replacing an LED Light Fixture: 步骤 8 中的图像 1,3 Replacing an LED Light Fixture: 步骤 8 中的图像 2,3 Replacing an LED Light Fixture: 步骤 8 中的图像 3,3
    • Unwrap the electrical tape from around both the black and white wires. These wires will be connected to the base of the light fixture with wire caps (which are yellow in this case).
    • You may want to rest the base of the light fixture on the top of your ladder, or have someone else hold it so that you can use both hands to unwrap the electrical tape.
  9. Replacing an LED Light Fixture: 步骤 9 中的图像 1,3 Replacing an LED Light Fixture: 步骤 9 中的图像 2,3 Replacing an LED Light Fixture: 步骤 9 中的图像 3,3
    • Remove the wire caps from the black and white wires and place them aside.
  10. Replacing an LED Light Fixture: 步骤 10 中的图像 1,3 Replacing an LED Light Fixture: 步骤 10 中的图像 2,3 Replacing an LED Light Fixture: 步骤 10 中的图像 3,3
    • Place a piece of electrical tape on the two black wires joined together by the yellow wire connector.
    • Wrap the electrical tape a few times around the wire until both wires are securely wrapped together.
    • Follow the same steps for the white wires.
  11. Replacing an LED Light Fixture: 步骤 11 中的图像 1,3 Replacing an LED Light Fixture: 步骤 11 中的图像 2,3 Replacing an LED Light Fixture: 步骤 11 中的图像 3,3
    • Screw on the new metal bracket from the replacement light fixture by twisting the manual Phillips screwdriver until the screw is snuggly holding the bracket.
    • This bracket will be placed in the same location that the original bracket was in, so the screw will screw into the same place as the original screw.
  12. Replacing an LED Light Fixture: 步骤 12 中的图像 1,3 Replacing an LED Light Fixture: 步骤 12 中的图像 2,3 Replacing an LED Light Fixture: 步骤 12 中的图像 3,3
    • Screw on the remaining screws into the metal bracket so that it is firmly attached to the ceiling.
  13. Replacing an LED Light Fixture: 步骤 13 中的图像 1,3 Replacing an LED Light Fixture: 步骤 13 中的图像 2,3 Replacing an LED Light Fixture: 步骤 13 中的图像 3,3
    • While holding the base of the new light fixture, tuck the black and white wires into the electrical box so that there is very little slack in the wires.
  14. Replacing an LED Light Fixture: 步骤 14 中的图像 1,2 Replacing an LED Light Fixture: 步骤 14 中的图像 2,2
    • Screw the base of the new light fixture into place.
  15. Replacing an LED Light Fixture: 步骤 15 中的图像 1,3 Replacing an LED Light Fixture: 步骤 15 中的图像 2,3 Replacing an LED Light Fixture: 步骤 15 中的图像 3,3
    • Position the light cover of the new light fixture onto the base.
    • Tighten the thumb screws which hold the light cover so that the cover is tightly secured to to the base.
  16. Replacing an LED Light Fixture: 步骤 16 中的图像 1,3 Replacing an LED Light Fixture: 步骤 16 中的图像 2,3 Replacing an LED Light Fixture: 步骤 16 中的图像 3,3
    • Flip the switch on the breaker back to the left to turn on the power to the light fixture.
  17. Replacing an LED Light Fixture: 步骤 17 中的图像 1,1
    • Test to ensure that the light fixture is working properly.
结论
Elijah Esmeralda
于04/15/24注册
273 声望
撰写一个指南
团队
UC Davis, Team 1-3, Morris Spring 2024 UC Davis, Team 1-3, Morris Spring 2024 的会员
UCD-MORRIS-S24S1G3
3 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 28
过去 30 天: 109
总计 1,413
