简介
Make it easier to zip up your favorite jacket by replacing a missing zipper pull tab. It only takes a few minutes and afterward you’ll be able to grib your zipper pull with mittens or gloves.
For replacement parts or further assistance, contact Patagonia Customer Service.
视频概述
Zipper pull replacement overview.
  1. Get your new zipper pull and position it with the pull-tab down. Lift up the zipper, as if you were pulling the zipper closed.
    • Get your new zipper pull and position it with the pull-tab down.
    • Lift up the zipper, as if you were pulling the zipper closed.
  2. Insert the zipper pull into the smaller hole in the zipper. This is the top hole when the zipper is hanging normally. Pull the zipper pull through the smaller hole. Pull the zipper pull through the smaller hole.
    • Insert the zipper pull into the smaller hole in the zipper. This is the top hole when the zipper is hanging normally.
    • Pull the zipper pull through the smaller hole.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Rest the zipper back in its normal, hanging position. Take top end of the zipper pull and insert it into the bigger, lower hole in the zipper.
    • Rest the zipper back in its normal, hanging position.
    • Take top end of the zipper pull and insert it into the bigger, lower hole in the zipper.
  5. Pull the top of the zipper pull through the hole to create a loop on the backside of the zipper. Bring the zipper pull-tab through the loop.
    • Pull the top of the zipper pull through the hole to create a loop on the backside of the zipper.
    • Bring the zipper pull-tab through the loop.
  6. Pull the zipper pull-tab snug. The zipper pull should now be inserted and lay flat.
    • Pull the zipper pull-tab snug.
    • The zipper pull should now be inserted and lay flat.
终点
3等其他人完成本指南。
Brittany McCrigler
于2012年03月05日注册
80,635 信誉积分
创作了132篇指南
团队
iFixit iFixit 的会员
Community
109 名成员
创作了7,715篇指南
浏览统计数据:
过去的24小时: 9
过去的7天: 63
过去的30天: 345
总计 12,372
