跳转到主内容
Replacing a Wheel on your Patagonia Wheeled Luggage
你所需要的
  1. Replacing a Wheel on your Patagonia Wheeled Luggage, Wheel: 步骤 1 中的图像 1,1
    • Lay the bag down, with the problem wheel facing you.
    • Zipping the bag closed will keep it from flopping about as you work.
  2. Replacing a Wheel on your Patagonia Wheeled Luggage: 步骤 2 中的图像 1,3 Replacing a Wheel on your Patagonia Wheeled Luggage: 步骤 2 中的图像 2,3 Replacing a Wheel on your Patagonia Wheeled Luggage: 步骤 2 中的图像 3,3
    • Using a hex 4.0 screwdriver, remove the threaded bolt in the center of of the wheel. This is the screw closest to the ground when the bag is upright.
    • Remove the bolt by pulling it straight out of the hole.
  3. Replacing a Wheel on your Patagonia Wheeled Luggage: 步骤 3 中的图像 1,2 Replacing a Wheel on your Patagonia Wheeled Luggage: 步骤 3 中的图像 2,2
    • Using one hand to lift and support the bag, take the wheel in your other hand. Pull the wheel out of its casing.
    • Removing the wheel may take a little force, do not be afraid to give it a tug.
    • To install your replacement wheel, follow these steps in reverse order with your new wheel.
终点
5等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
89,011 声望
创作了131篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,731篇指南
2条评论
What do you do when the nut inside the wheel housing comes loose? I can hear it rolling around in the housing. The bolt has nothing to screw back into. Is there any way to take the housing off? It looks to be held on by rivets. I'm guessing that's not a good sign.
Derek Emanuel - 回复
Helpful but where do you get the replacement wheel from. My brand new Black Hole 100L bag showed up in Lisbon Portugal with one wheel missing. Need to get another wheel and screw. Can I order that from Patagonia and have them ship to a friend that is coming here? Is that best route to take? Thanks
Craig Klinger - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 80
总计 10,998
