当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Dig a one foot wide hole around the broken sprinkler extension down to the pipe fitting.
The pipe fitting is usually about one foot underground.
Dig around the pipe fitting with a trowel to provide clear access.
Clean the area around the fitting with water until the fitting is mostly free of dirt.
Unscrew the sprinkler extension from the pipe fitting.
Once the extension is removed, water may come out of the open pipe fitting.
Screw the new sprinkler extension in securely.
Test the sprinkler to ensure that there are no leaks.
Refill the hole tightly.
取消:我没有完成这个指南。
与4其他贡献者
于09/11/15注册
111 声望
撰写一个指南
徽章: 3
SHSU-NARDONE-F15S16G5
5 名成员
创作了1篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 23
总计 813
