跳转到主内容
Replacing a Sprinkler Extension
你所需要的
  1. Replacing a Sprinkler Extension, Sprinkler Extension: 步骤 1 中的图像 1,1
    • Dig a one foot wide hole around the broken sprinkler extension down to the pipe fitting.
    • The pipe fitting is usually about one foot underground.
  2. Replacing a Sprinkler Extension: 步骤 2 中的图像 1,1
    • Dig around the pipe fitting with a trowel to provide clear access.
  3. Replacing a Sprinkler Extension: 步骤 3 中的图像 1,1
    • Clean the area around the fitting with water until the fitting is mostly free of dirt.
  4. Replacing a Sprinkler Extension: 步骤 4 中的图像 1,2 Replacing a Sprinkler Extension: 步骤 4 中的图像 2,2
    • Unscrew the sprinkler extension from the pipe fitting.
    • Once the extension is removed, water may come out of the open pipe fitting.
  5. Replacing a Sprinkler Extension: 步骤 5 中的图像 1,1
    • Screw the new sprinkler extension in securely.
  6. Replacing a Sprinkler Extension: 步骤 6 中的图像 1,2 Replacing a Sprinkler Extension: 步骤 6 中的图像 2,2
    • Test the sprinkler to ensure that there are no leaks.
    • Refill the hole tightly.
结论
If you have completed the steps successfully you should have a fully functioning sprinkler extension.
Abagayle Serreyn
于09/11/15注册
111 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 20
总计 1,072
